NSL-6110
NSL-6110
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL CDS 170OHM TO-18
NSL-6110 数据手册
NSL-6110 TO-18 Hermetic Photocell Description The NSL-6110 is a light dependent resistor with sensitivity in the visible light region. The CdS photoconductive material is supplied in a TO-18 hermetically sealed package. Absolute Maximum Ratings Operating & Storage Temp Power Dissipation @ 25C (1) Voltage (peak AC or DC) Soldering Temperature (3) -60C to +75C 50 mW 100 V 260C 3.8 +/- 0.1 5.3 - 5.6 R0.1 34 +/- 0.5 4.6 +/- 0.1 3.7 - 3.9 2.5 +/- 0.1 0.3 R0.2 0.5 +/- 0.1 Dimensions in mm. Electrical Characteristics (TA=25C, and source at 2854 K) (2) Symbol Parameter Min Typ Max. Units RL Light Resistance 1.34 2.0 2.66 K 170  RD Dark Resistance 1.3 M Peak spectral wavelength 615 nm P Specifications subject to change without notice. Test Conditions 2 Ftc., (2) 100 Ftc. 5 sec after removal of light REV 06/02-14 Notes: (1) Derate linearly to zero at 75C (2) Cells light adapted at 30 to 50 Ftc for 16 hrs. minimum prior to electrical tests (3)  0.05” from case for < 10 sec. (4) Print “NSL-6110” and data code “YYWW” on window can. Advanced Photonix Canada Inc., 300 St-Sacrement Suite 519 Montréal, QC, Canada H2Y 1X4 Page 1 Phone:(514) 768-8000 Fax: (514) 768-8889 http://www.advancedphotonix.com
NSL-6110 价格&库存
很抱歉,暂时无法提供与“NSL-6110”相匹配的价格&库存,您可以联系我们找货
NSL-6110
库存:389
