PHOTONIC Cadmium Sulfoselenide (CdS) Photoconductive Photocells
Type PDV-P700X
DETECTORS INC.
INDUSTRY EQUIVALENTS
VT800 & NSL-4000 &5000 series
PACKAGE DIMENSIONS INCH [mm]
+.015 [0.38]
-.010 [0.25]
.079 [2.00]
EPOXY ON LEADS 3mm MAX
±.010 [0.25]
.249 [6.31]
2X Ø.016 [0.40]
±.010 [0.25]
Ø.263 [7.20]
2
.200 [5.08]
PLASTIC
COATED
1
1.437 [36.5] MIN
PLASTIC COATED CERAMIC PACKAGE
1. PHOTOCELL "GRID" PATTERN CAN VARY, PDI RESERVES THE RIGHT TO CHANGE
AND MIX GRID PATTERNS.
2. DIMENSION CONTROLLED AT BASE OF CERAMIC HEADER PACKAGE.
FEATURES
Visible light response
Sintered construction
Low cost
High Reliability
V PK
Applied Voltage
350
V dc
Pd
Continuous Power Dissipation
400
mW OC
po/ t
Tstg & To
TS
+75
O
+260
O
-30
Operating Temperature Range & Storage
Soldering Temperature*
C
APPLICATIONS
Audio equipment
Electronic Toys
Modulation circuits
Volume controls
CELL RESISTANCE VS. ILLUMINANCE
K Ohms
DESCRIPTION
PDV-P700X are (CdS) photoconductive
photocells designed to sense light from 400
nm to 700 nm. As light dependent resistors,
they are available in a wide range of resistance values. They are packaged in a two
leaded plastic-coated ceramic header.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
C
*.200 inch (5 mm) from bottom of header for 3 secs max with heat sink
Lux
ELECTRO-OPTICAL CHARACTERISTICS TA=25OC (2 HOURS LIGHT ADAPT, MIN)***
MODEL NO.CELL RESISTANCE** (Ohms)
10 Lux @2856K
DARK
MIN (K W
W) MAX (K W
W) MIN (M W
W) SEC
SENSITIVITY
LOG(R100)-LOG(R10)
LOG (E100)-LOG(E10)
(l
l TYP)
SPECTRAL PEAK
RESPONSE TIME @10 Lux
(nm)
RISE TIME (ms)
FALL TIME (ms)
TYP
TYP
TYP
PDV-P7001
3.6
14.4
0.3
10
0.6
520
50
PDV-P7002
4
10
0.65
520
55
PDV-P7003
8
24
0.5
10
0.7
PDV-P7004
15
60
0.5
10
0.7
520
60
25
PDV-P7005
50
150
0.85
520
60
25
520
55
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. ** Photocells are light adapted at 100 to 500 Lux. *** Photocells are tested at 2856 oK at a 10 Lux [FORM NO. 100-PDV-P7001 REV N/C]
light level. Resistance values are for reference only.
PAGE 1 OF 1
很抱歉,暂时无法提供与“PDV-P7004”相匹配的价格&库存,您可以联系我们找货
