PDV-P8105
PDV-P8105
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 50-94KOHM
PDV-P8105 数据手册
CDS Photoconductive Photocells PDV-P8105 Precision – Control – Results WWW.LUNAINC.COM DESCRIPTION FEATURES The PDV-P8105 are (CdS), Photoconductive photocells designed to sense light from 400 to 700 nm. These light dependent resistors are available in a wide range of resistance values. They’re packaged in a two leaded plastic-coated ceramic header.    RELIABILITY APPLICATIONS Contact Luna for recommendations on specific test conditions and procedures.    Visible light response Sintered construction Low cost Camera exposure Shutter controls Night light controls ABSOLUTE MAXIMUM RATINGS SYMBOL MIN MAX UNITS (TA)= 23°C UNLESS OTHERWISE NOTED Applied Voltage - - 150 V - Continuous Power Dissipation - - 100 mW/°C - -30 to +75 V - - - +260 °C - Operation and Storage Temperature Soldering Temperature* * 0.200 inch from base for 3 seconds with heat sink. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 1/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 CDS Photoconductive Photocells PDV-P8105 Precision – Control – Results WWW.LUNAINC.COM Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS TEST CONDITIONS PARAMETER MIN TYP MAX UNITS Dark Resistance After 10 sec. @10 Lux @ 2856°K 2.5 - - MΩ Illuminated Resistance 10 Lux @ 2856°K 50 - 94 KΩ - .85 - Lux Sensitivity Spectral Application Range Flooded 400 - 700 nm Spectral Application Range Flooded - 520 - nm Rise Time 10 Lux @ 2856 °K - 60 - ms Fall Time After 10 Lux @ 2856 °K - 25 - ms **R100, R10: cell resistances at 100 Lux and 10 Lux at 2856 K respectively . ***E100, E10: luminances at 100 Lux and 10 Lux 2856 K respectively. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 10-24-16 Page 2/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDV-P8105 价格&库存
很抱歉,暂时无法提供与“PDV-P8105”相匹配的价格&库存,您可以联系我们找货
