PDV-P7005
PDV-P7005
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTOCELL 50K-150K OHM 7.2MM
PDV-P7005 数据手册
PHOTONIC Cadmium Sulfoselenide (CdS) Photoconductive Photocells Type PDV-P700X DETECTORS INC. INDUSTRY EQUIVALENTS VT800 & NSL-4000 &5000 series PACKAGE DIMENSIONS INCH [mm] +.015 [0.38] -.010 [0.25] .079 [2.00] EPOXY ON LEADS 3mm MAX ±.010 [0.25] .249 [6.31] 2X Ø.016 [0.40] ±.010 [0.25] Ø.263 [7.20] 2 .200 [5.08] PLASTIC COATED 1 1.437 [36.5] MIN PLASTIC COATED CERAMIC PACKAGE 1. PHOTOCELL "GRID" PATTERN CAN VARY, PDI RESERVES THE RIGHT TO CHANGE AND MIX GRID PATTERNS. 2. DIMENSION CONTROLLED AT BASE OF CERAMIC HEADER PACKAGE. FEATURES Visible light response Sintered construction Low cost High Reliability V PK Applied Voltage 350 V dc Pd Continuous Power Dissipation 400 mW OC po/ t Tstg & To TS +75 O +260 O -30 Operating Temperature Range & Storage Soldering Temperature* C APPLICATIONS Audio equipment Electronic Toys Modulation circuits Volume controls CELL RESISTANCE VS. ILLUMINANCE K Ohms DESCRIPTION PDV-P700X are (CdS) photoconductive photocells designed to sense light from 400 nm to 700 nm. As light dependent resistors, they are available in a wide range of resistance values. They are packaged in a two leaded plastic-coated ceramic header. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS C *.200 inch (5 mm) from bottom of header for 3 secs max with heat sink Lux ELECTRO-OPTICAL CHARACTERISTICS TA=25OC (2 HOURS LIGHT ADAPT, MIN)*** MODEL NO.CELL RESISTANCE** (Ohms) 10 Lux @2856K DARK MIN (K W W) MAX (K W W) MIN (M W W) SEC SENSITIVITY LOG(R100)-LOG(R10) LOG (E100)-LOG(E10) (l l TYP) SPECTRAL PEAK RESPONSE TIME @10 Lux (nm) RISE TIME (ms) FALL TIME (ms) TYP TYP TYP PDV-P7001 3.6 14.4 0.3 10 0.6 520 50 20 PDV-P7002 4 20 0.5 10 0.65 520 55 20 PDV-P7003 8 24 0.5 10 0.7 PDV-P7004 15 60 0.5 10 0.7 520 60 25 PDV-P7005 50 150 20 10 0.85 520 60 25 520 55 20 Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** Photocells are light adapted at 100 to 500 Lux. *** Photocells are tested at 2856 oK at a 10 Lux [FORM NO. 100-PDV-P7001 REV N/C] light level. Resistance values are for reference only. PAGE 1 OF 1
PDV-P7005 价格&库存
很抱歉,暂时无法提供与“PDV-P7005”相匹配的价格&库存,您可以联系我们找货
