SBH21-NBPN-D25-SM-BK-M81RC 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2746
INITIAL RELEASE
03/13/2013
LH
B
2835
UPGRADE INSULATOR MATERIAL NYLON 9T(WAS NYLON 6T), UPDATE
SMT TAIL COPLANAR TOLERANCE, AND ADD WARP TOLERANCE AND 04/07/2014
UPDATE NOTE 5(WAS INSULATOR RESISTANCE: 1000 MEGOHMS MIM.)
LH
C
3708
F
UPDATE T&R 'W' DIMENSION ON PAGE 2
07/12/2017
F
LH
C .008 [ 0.20]
A
.256 6.50
A
E
.079 2.00
.079 2.00
.173 4.40
.157 4.00
.040 1.02
.154 3.90
.315 8.00
.039 1.00
E
.339 8.60
.260 6.60
.157 4.00
.256 6.50
D
D
.220 5.60
RECOMMENDED PCB LAYOUT
.274 6.95
.004 [0.10] 03-25 POSITIONS
.006 [0.15] 30-34 POSITIONS
.299 7.60
03 - 20, .008 [0.20] MAX.
22 - 30, .012 [0.30] MAX.
34, .016 [0.40] MAX.
C
C
B .008 [ 0.20]
.079 2.00
.020 0.50
.213 5.40
B
A
B
NOTES:
1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK
2. CONTACT MATERIAL: BRASS
3. CONTACT PLATING: .000030" - .000050" NICKEL UNDERPLATED, GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS
5. INSULATOR RESISTANCE: 5,000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 500V AC
8. OPERATING TEMPERATURE: -40°C TO + 105°C
9. PROCESSING TEMP.: 230°C MAX FOR 60 SECONDS
( 260°C MAX FOR 10 SECONDS )
10. MATES WITH SFH21 & SFH213 IDC SOCKET SERIES
11. MODIFICATION: WITH PICK & PLACE CAP IN TAPE & REEL
8
7
6
5
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
DECIMALS
X.XX= .01 [.3]
X.XXX= .008 [.20]
X.XXXX= .0040 [.100]
DRAWN
DATE
NAME
03/13/2013 LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
BOX HEADER .079" [2.00mm] PITCH, SMT, W/T&R
PART NUMBER
SIZE
C
SBH21-NBPN-D_ _-SM-BK-M81
CAGE CODE
54453
SCALE: 4:1
3
2
DWG. NO.
REV
12161
SHEET 1 OF 2
1
C
FILE NAME: 12161, SBH21-NBPN-D_ _-SM-BK-M81
A
4
5
NOTE:
1. CUMULATIVE PITCH TOLERANCE FOR 10 SPROCKET HOLES IS 0.20mm.
2. CARRIER CAMBER IS 1mm IN 100mm.
3. A0 AND B0 MEASURED ON A PLANE 0.3mm ABOVE THE BOTTOM
OF THE POCKET.
4. K0 MEASURED FROM A PLANE ON THE INSIDE BOTTOM OF THE
POCKET TO THE TOP SURFACE OF THE CARRIER.
5. PACKING CONFORMS EIA-481-2 STANDARDS.
6. ONE 13" REEL= 8.0 METER (OVERALL LENGTH OF TAPE), 500 PIECES.
1
2
3
F
FEEDING DIRECTION
TAPE TYPE 1: FOR POSITION NUMBERS 05 THRU 34(TAPE WIDTH ≥ 32 mm)
P0
P2
W
6
D
F
7
E
8
F
POLARIZATION DIRECTION
E
6°
60°
DIMENSION UNIT: mm
B0
E
50°
6°
A0
3
P
K0
TAPE TYPE 2: FOR POSITION NUMBERS 03 THRU 04(TAPE WIDTH < 32 mm)
D
D
W
P2
F
D
E
P0
B0
6°
60°
50°
6°
A0
C
C
3
P
K0
T
2.0
2.0
DIMENSION UNIT: mm
C
FEEDING DIRECTION
B
D
81.5±0.2
A
N
B
G
B
DRAWN
Pb
A
8
7
6
5
ANGULAR:
4
NAME
03/13/2013
LH
TOLERANCES:
RoHS COMPLIANT
DATE
DECIMALS
X.XX= .01 [.3]
X.XXX= .008 [.20]
TITLE
PART NUMBER
SIZE
C
3
CAGE CODE
54453
DWG. NO.
12161
SCALE: 4:1
SHEET 2 OF 2
2
1
REV
C
FILE NAME: C:\Users\LHsu.SEC\Desktop\ECO 3708, SBH11 & SBH21 T&R UPDATE\DWG 12161-B\12161, SBH21-NBPN-D_ _-SM-BK-M81\12161, SBH21-NBPN-D_ _-SM-BK-M81 PRINT: 7/24/2017
A
SBH21-NBPN-D25-SM-BK-M81RC 价格&库存
很抱歉,暂时无法提供与“SBH21-NBPN-D25-SM-BK-M81RC”相匹配的价格&库存,您可以联系我们找货
