TSL13FN
TSL13FN
    AMSOSRAM(艾迈斯半导体)
    WDFN6
    IC SENSOR LIGHT-VOLT 6DFN
TSL13FN 数据手册
TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters TSL13FN Light-to-Voltage Converters on tro lle d The TSL13FN is a cost optimized, highly integrated light-to-voltage optical sensor that contains a photodiode and a transimpedance amplifier with a 20 MΩ feedback resistor on a single monolithic integrated circuit. The photodiode active area is 0.5mm x 0.5mm and the sensor responds to visible light in the range of 300 nm to 1100 nm. The output voltage is linear with light intensity (irradiance) incident on the sensor over a wide dynamic range. These devices are supplied in a surface mountable package. General Description Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features tC The benefits and features of TSL13FN are listed below: no Figure 1: Added Value of Using TSL13FN Single Diode High Irradiance Responsivity to Green Features to Approximates Human Eye Response in ut Benefits Pr 18.7 mV/(μW/cm2) at λp = 525nm 0.8mA Typical t- Low Supply Current Do Ef fe cti ve Figure 2: TSL13FN Block Diagram The functional blocks of this device for reference are shown below: cu m en Block Diagram Voltage Output + ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 1 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Pin Assignment Pin Assignment Figure 3: Pin Diagram (Top View) VDD 1 OUTPUT 2 NO CONNECT 3 6 GND 5 NO CONNECT on tro lle d 4 NO CONNECT tC Pin Description no Figure 4: Pin Description Pin Name Description 1 VDD Supply voltage 2 OUT Output voltage 3 N/C No connection 4 N/C No connection 5 N/C 6 GND en t- Pr in to ut Pin Number Power supply ground. All voltages are referenced to GND Ef fe cti ve Do cu m No connection TSL13FN – 2 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute Maximum Ratings Figure 5: Absolute Maximum Ratings Parameter Min Max Units Comments 6 V All voltages are with respect to GND VDD Supply voltage IO Output current -10 10 mA Storage temperature range -40 85 ºC Ef fe cti ve Do cu m en t- Pr in to ut no tC Tstg on tro lle d Symbol ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 3 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Electrical Characteristics Figure 6: Recommended Operating Conditions Symbol Parameter VDD TA Min Typ Max Units Supply voltage 2.7 5.5 V Operating free-air temperature -30 70 °C Symbol Conditions Min Maximum output voltage 4.6 λp = 525 nm 1.5 Re Irradiance responsivity λp = 525nm (4) VOS Extrapolated offset voltage see note (4) -0.02 Vd Dark voltage t- to ut λp = 850 nm Ee = 0 μW/cm2 0 ID Supply current 2.5 V 2 2.5 mV/(μW /cm2) 18.7 in Pr en Ee = 107 μW/cm2 2 V 0.03 0.8 0.08 V 0.08 V 1.3 mA cu m λp = 525 nm Units no Output voltage Ee = 70.5 μW/cm2 Max 4.9 1.5 Ee = 107 μW/cm2 VO Typ tC VOM Parameter on tro lle d Figure 7: Operating Characteristics, VDD = 5 V, TA = 25ºC, λp = 525 nm (unless otherwise noted) (1), (2), (3) Do Note(s) and/or Footnote(s): 1. Optical measurements are made using small-angle incident radiation from an LED optical source. ve 2. The 525 nm irradiance Ee is supplied by a InGaN light-emitting diode with the following typical characteristics: peak wavelength λp = 525 nm and spectral halfwidth Δλ½ = 40 nm. cti 3. The 850 nm irradiance Ee is supplied by a light-emitting diode with the following typical characteristics: peak wavelength λp = 850 nm and spectral halfwidth Δλ½ = 42 nm. Ef fe 4. Irradiance responsivity is characterized over the range VO = 0.2 to 4 V. The best-fit straight line of output voltage VO versus irradiance Ee over this range may have a positive or negative extrapolated VO value for Ee = 0. For low irradiance values, the output voltage VO versus irradiance Ee characteristic is nonlinear with a deviation toward VO = 0, Ee = 0 origin from the best-fit straight line referenced above. TSL13FN – 4 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Electrical Characteristics Figure 8: Dynamic Characteristics, VDD = 5 V, TA = 25ºC, λp = 525 nm, RL = 10 kΩ (unless otherwise noted) (see also Figure 9) Parameter Conditions Min Typ Max Units tdr Output pulse delay time for rising edge (0% to 10%) Min VO = 0V; Peak VO = 2V Min VO = 0.5V; Peak VO = 2V 1.7 1.2 μs tr Output pulse rise time (10% to 90%) Min VO = 0V; Peak VO = 2V Min VO = 0.5V; Peak VO = 2V 7.2 6.5 μs tdf Output pulse delay time for falling edge (100% to 90%) Min VO = 0V; Peak VO = 2V Min VO = 0.5V; Peak VO = 2V 1.2 1.1 μs tf Output pulse fall time (90% to 10%) Min VO = 0V; Peak VO = 2V Min VO = 0.5V; Peak VO = 2V on tro lle d Symbol 6.8 6.4 tC Timing Diagrams μs cu m en t- Pr in to ut no Figure 9: Parameter Measurement Information Do Note(s) and/or Footnote(s): 1. The input irradiance is supplied by a pulsed InGaN light emitting diode with the following characteristics: λ p = 525 nm, t r < 1 μs, tf < 1 μs. Ef fe cti ve 2. The output waveform is monitored on an oscilloscope with the following characteristics: tr < 100 ns, Zi ≥ 1 MΩ, C i ≤ 20 pF. ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 5 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Typical Operating Characteristics Figure 10: Spectral Responsivity 1 0.8 0.7 0.6 0.5 0.4 on tro lle d Normalized Responsivity 0.9 0.3 0.2 0.1 0 300 400 500 600 700 800 900 1000 1100 ut no tC λ - Wavelength - nm in to Figure 11: Normalized Output Voltage vs. Angular Response Pr 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% -90 -75 -60 -45 -30 -15 0 15 30 45 60 75 90 Incident Angle - (º) Ef fe cti ve Do cu m en t- Response – Normalized to 0º 100% TSL13FN – 6 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 12: Rising Edge Dynamic Characteristics vs. Peak Output Voltage (Min VO = 0V) 20 Min VO = 0V 12 tr 8 4 on tro lle d Time - μs 16 tdr 0 0 0.5 1 1.5 2 2.5 3 3.5 4 no tC Vo - Peak Output Voltage - V Pr 20 in to ut Figure 13: Rising Edge Dynamic Characteristics vs. Peak Output Voltage (Min VO = 0.5V) Min VO = 0.5V Time - μs 12 tr 8 4 tdr 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Vo - Peak Output Voltage - V Ef fe cti ve Do cu m en t- 16 ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 7 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 14: Falling Edge Dynamic Characteristics vs. Peak Output Voltage (Min VO = 0V) 30 Min VO = 0V 25 Time - μs 20 15 tf 5 on tro lle d 10 tdf 0 0 0.5 1 1.5 2 2.5 3 3.5 4 no tC Vo - Peak Output Voltage - V in to ut Figure 15: Falling Edge Dynamic Characteristics vs. Peak Output Voltage (Min VO = 0.5V) Pr 30 Min VO = 0.5V Time - μs 20 15 10 tf 5 tdf 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Vo - Peak Output Voltage - V Ef fe cti ve Do cu m en t- 25 TSL13FN – 8 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters P C B Pa d L a y o u t PCB Pad Layout tC on tro lle d Figure 16: Suggested FN Package PCB Layout ut no Pads can be extended further if hand soldering is needed! Note(s) and/or Footnote(s): to 1. All linear dimensions are in millimeters. Ef fe cti ve Do cu m en t- Pr in 2. This drawing is subject to change without notice. ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 9 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Pack age Drawings & Mark ings Package Drawings & Markings Figure 17: Six-lead Surface Mount FN Package Configuration TOP VIEW 500 on tro lle d 2000±100 500 tC PHOTODIODE ACTIVE AREA 2000±100 END VIEW no 295 NOMINAL 6X 97±20 to ut 650±50 6X 300±50 in 4X 650 Pr BOTTOM VIEW CL OF PHOTODIODE ACTIVE AREA CL OF SOLDER CONTACTS SEE NOTE 2 6X 750±150 fe cti ve Do cu m en t- CL OF PHOTODIODE ACTIVE AREA CL OF SOLDER CONTACTS SEE NOTE 2 Note(s) and/or Footnote(s): Ef 1. All linear dimensions are in micrometers. 2. The Photodiode Active Area is centered within the package within a tolerance of ±75 micrometers. 3. Package top surface is molded with an electrically nonconductive clear plastic compound having an index of refraction of 1.55. 4. Contact finish is Copper Alloy A194 with pre-plated NiPdAu lead finish. 5. This package contains no lead (Pb). 6. This drawing is subject to change without notice. TSL13FN – 10 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Mechanical Data Mechanical Data cti ve Do cu m en t- Pr in to ut no tC on tro lle d Figure 18: Six-lead Surface Mount FN Package Carrier Tape fe Note(s) and/or Footnote(s): Ef 1. All linear dimensions are in millimeters. 2. The dimensions in this drawing are for illustration purposes only. Dimensions of an actual carrier may vary slightly. 3. Symbols on drawing A0, B0 and K 0 are defined in ANSI EIA standard 481-B 2001. 4. Each reel is 178 millimeters in diameter and contains 1000 parts. 5. ams packaging tape and reel conform to the requirements of EIA 481-B. 6. In accordance with EIA standard, the device pin1 is located next to the sprocket holes in the tape. 7. This drawing is subject to change without notice. ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 11 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Soldering & Storage Information Soldering & Storage Information Soldering Information The reflow profile specified here describes expected maximum heat exposure of devices during the solder reflow process of the device on a PCB. Temperature is measured at the top of the device. Devices should be limited to one pass through solder reflow profile. Figure 19: Solder Reflow Profile Parameter TSL13FN on tro lle d Symbol 2.5°C/sec Soak time 2 to 3 minutes t1 Time above T1, 217°C Max 60 sec t2 Time above T2, 230°C Max 50 sec t3 Time above T3, (Tpeak - 10°C) Tpeak Peak temperature in reflow no Max 10 sec 260°C(-0°C/+5°C) ut tsoak tC Average temperature gradient in preheating Max -5°C/sec in to Temperature gradient in cooling Ef fe cti ve Do cu m en t- Pr Figure 20: Solder Reflow Graph Note: Not to scale – for reference only. TSL13FN – 12 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Soldering & Storage Information Storage Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is baked prior to being dry packed for shipping. Devices are dry packed in a sealed aluminized envelope called a moisture-barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. on tro lle d This package has been assigned a moisture sensitivity level of MSL3 and the devices should be stored under the following conditions. • Temperature Range: 5°C to 50°C • Relative Humidity: 60% maximum tC • Total Time: 12 months from the date code on the aluminized envelope – if opened no • Open Time: 168 hours or less Ef fe cti ve Do cu m en t- Pr in to ut Re-baking will be required if the devices have been stored unopened for more than 12 months or the aluminized envelop has been open for more than 168hrs. If re-baking is required, it should be done at 50°C for 12 hours. ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 13 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Ordering & Contact Information Ordering & Contact Information Figure 21: Ordering Information Device TA Package Description Package Designator Ordering Number TSL13 0 to 70°C 6-lead Surface Mount FN TSL13FN Buy our products or get free samples online at: www.ams.com/ICdirect on tro lle d Technical Support is available at: www.ams.com/Technical-Support For further information and requests, e-mail us at: ams_sales@ams.com to ut no Headquarters ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten Austria, Europe tC For sales offices, distributors and representatives, please visit: www.ams.com/contact in Tel: +43 (0) 3136 500 0 Ef fe cti ve Do cu m en t- Pr Website: www.ams.com TSL13FN – 14 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. RoHS Compliant & ams Green Statement ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Ef fe cti ve Do cu m en t- Pr in to ut no tC on tro lle d Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 15 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. tC on tro lle d Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. Ef fe cti ve Do cu m en t- Pr in to ut no ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. TSL13FN – 16 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Document Status Document Status Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs Datasheet Ef fe cti ve Do cu m en t- Pr in to ut Datasheet (discontinued) on tro lle d Preliminary Datasheet Definition tC Product Preview Product Status no Document Status ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 17 TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Revision Information Revision Information Changes from 0-03 (2013-Nov) to current revision 1-00 (2014-Jun-04) Page Ef fe cti ve Do cu m en t- Pr in to ut no tC on tro lle d Content was updated to the latest ams design TSL13FN – 18 Release Date: 2014-06-17, Key Contact: Matt Kroese ams Datasheet: 2014-Jun-04 [1-00] TSL13FN_Datasheet, Rev.: 1.0, TSL13FN_Datasheet_[1-00]_Light-To-Voltage Converters Content Guide General Description Key Benefits & Features Block Diagram 2 2 3 Pin Assignment Pin Description Absolute Maximum Ratings 4 5 Electrical Characteristics Timing Diagrams 6 9 10 11 Typical Operating Characteristics PCB Pad Layout Package Drawings & Markings Mechanical Data 12 12 13 13 Soldering & Storage Information Soldering Information Storage Information Moisture Sensitivity 14 15 16 17 18 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ut no tC on tro lle d 1 1 1 Ef fe cti ve Do cu m en t- Pr in to Content Guide ams Datasheet: 2014-Jun-04 [1-00] Release Date: 2014-06-17, Key Contact: Matt Kroese TSL13FN – 19
TSL13FN 价格&库存
很抱歉,暂时无法提供与“TSL13FN”相匹配的价格&库存,您可以联系我们找货
