UV Enhanced Silicon Photodiode
SD100-13-23-222
Advanced Photonix, Inc.
Precision – Control – Results
WWW.ADVANCEDPHOTONIX.COM
P A C K A G E D IM E N S IO N S IN C H [m m ]
.1 6 9 [4 .2 9 ]
.1 5 7 [3 .9 9 ]
45°
.0 9 0 [2 .2 9 ]
3 X Ø .0 1 8 [0 .4 6 ]
1
Ø .2 0 0 [5 .0 8 ]
Ø .2 6 4 [6 .7 0 ]
Ø .2 5 6 [6 .5 0 ]
Ø .3 3 0 [8 .3 8 ]
P IN C IR C L E
90°
V IE W IN G
2
ANG LE
Ø .3 2 0 [8 .1 3 ]
3
Ø .3 6 2 [9 .1 9 ]
.0 1 0 [0 .2 5 ] M A X
Ø .3 5 7 [9 .0 7 ]
G LASS ABO VE C AP
3 X .5 0 0 [1 2 .7 ] M IN
TOP EDGE
1 ANODE
C H IP D IM E N S IO N S IN C H [m m ]
2 CASE GROUND
.1 1 8 [3 .0 0 ]
3 CATHODE
SQUARE
S C H E M A T IC
Ø .1 0 0 [Ø 2 .5 4 ]
A C T IV E A R E A
T O -5 P A C K A G E
DESCRIPTION
The SD 100-13-23-222 is UV enhanced silicon PIN photodiode assembled in a
hermetic TO-5 metal package with isolated pins.
FEATURES
Low Noise
High Speed
High shunt resistance
High response
RELIABILITY
This API high-reliability detector is in principle able to meet military test
requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test.
Contact API for recommendations on specific test conditions and procedures.
APPLICATIONS
Instrumentation
Medical
Industrial
ABSOLUTE MAXIMUM RATINGS
PARAMETER
Reverse Voltage
Operating Temperature
Storage Temperature
Soldering Temperature
Information in this technical datasheet is believed to
be correct and reliable. However, no responsibility is
assumed for possible inaccuracies or omission.
Specifications are subject to change without notice.
MIN
-40
-55
MAX
50
+125
+150
+260
UNITS
V
°C
°C
°C
Ta = 23°C
non condensing
see recommended reflow profile
REV 12-03-14
Page 1/2
© 2014 Advanced Photonix, Inc. All rights reserved.
Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
SD100-13-23-222
Ta = 23°C unless noted otherwise
OPTO-ELECTRICAL PARAMETERS
CHARACTERISTIC
Dark Current
Shunt Resistance
Junction Capacitance
Spectral Application Range
Responsivity
Breakdown Voltage
Noise Equivalent Power
Response Time
TEST CONDITIONS
MIN
200
250
0.10
30
MAX
UNITS
1
300
90
9
0.18
50
3x10-14
6.5
1100
nA
M
pF
pF
nm
A/W
V
W/Hz1/2
RL = 50 ,VR = 0 V
190
RL = 50 ,VR = 10 V
13
VR = 5V
VR = 10 mV
VR = 0 V, f = 1 MHz
VR = 50 V, f = 1 MHz
Spot Scan
l= 365 nm V, VR = 0 V
I = 10 µA
VR = 0V @ l=Peak
TYP
nS
TYPICAL PERFORMANCE
SPECTRAL RESPONSE
0.6
0.5
Responsivity,A/W
0.4
0.3
0.2
0.1
325
425
525
625
725
Wavelenght, nm
825
925
1025
1125
REV 12-03-14
Page 2/2
很抱歉,暂时无法提供与“SD100-13-23-222”相匹配的价格&库存,您可以联系我们找货
