SD040-101-411
SD040-101-411
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE UV MICRO 1206 SMT
SD040-101-411 数据手册
SMT Photodiode Assembly SD 040-101-411 Advanced Photonix, Inc. ACTIVE AREA 0.9 x 0.9 sq.mm [0.035 x 0.035 sq. inch] FEATURES • • • Small Footprint Low Capacitance High Speed DESCRIPTION The SD040-101-411 is an UV Enhanced Silicon Photodiode assembled in a 1206 SMT package. ABSOLUTE MAXIMUM RATING • • • APPLICATIONS Industrial Sensors Light Management Handheld Devices TYPICAL SPECTRAL RESPONSE Ta = 25°C UNLESS OTHERWISE NOTED SYMBOL VR TOp TStg TS PARAMETER Reverse Voltage Operating Temperature Storage Temperature Soldering Temperature MIN MAX 50 -40 +105 -50 +125 +260 UNITS V °C °C °C ELECTRO-OPTICAL CHARACTERISTICS RATING SYMBOL Vf IL Vbr Rsh Id Cj CHARACTERISTIC Forward Voltage Light Current (2856K) Breakdown Voltage Shunt Resistance Dark Current Junction Capacitance TEST CONDITIONS If=10 mA VR = 5V; H = 1000 lux IR = 100 µA Vbias = 10 mV VR = 10 V VR = 5V; f = 1000 kHz Ta= 25°C, UNLESS OTHERWISE NOTED MIN 0.5 50 - TYP 0.8 9.0 1.0 20 MAX 1.3 0.5 - UNITS V uA V GΩ nA pF Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 • www.advancedphotonix.com REV 07/23/14
SD040-101-411 价格&库存
很抱歉,暂时无法提供与“SD040-101-411”相匹配的价格&库存,您可以联系我们找货
