SD019-141-411-IR920
SD019-141-411-IR920
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE MICRO 0805 SMT
SD019-141-411-IR920 数据手册
SMT Photodiode Assembly SD019-141-411 IR920 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM DESCRIPTION The SD019-141-411 IR920 is an IR band-pass filtered Silicon Photodiode, assembled in a 0805 SMT package. FEATURES  Small Footprint  Low Capacitance  High Speed RELIABILITY APPLICATIONS This API high-reliability detector is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact API for recommendations on specific test conditions and procedures.  Industrial Sensors  Light Management  Handheld Devices ABSOLUTE MAXIMUM RATINGS PARAMETER Reverse Voltage Operating Temperature Storage Temperature Soldering Temperature* MIN -40 -50 - Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. MAX 50 +105 +125 +260 UNITS V °C °C °C Ta = 23°C non condensing see recommended reflow profile REV 11-20-14 Page 1/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 SMT Photodiode Assembly SD019-141-411 IR920 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM Ta = 23°C unless noted otherwise OPTO-ELECTRICAL PARAMETERS CHARACTERISTIC TEST CONDITIONS MIN TYP MAX UNITS Forward Voltage If=10 mA 0.5 0.8 1.3 V Breakdown Voltage 50 - - V Shunt Resistance IR = 100 A Vbias = 10 mV - 2 - G Dark Current VR = 10 V - 20 500 pA Junction Capacitance VR = 5V; f = 1000 kHz - 6.0 - Rise Time @ 920 nm VR = 3V; Ri= 1000 - - 1.0 Responsivity (-IR) VR = 0V;  = 920 nm - 0.4 - pF N nS A/W TYPICAL PERFORMANCE SPECTRAL RESPONSE Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 11-20-14 Page 2/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
SD019-141-411-IR920 价格&库存
很抱歉,暂时无法提供与“SD019-141-411-IR920”相匹配的价格&库存,您可以联系我们找货
