InGaAs Photodiode
SD039-121-011
Advanced Photonix, Inc.
Precision – Control – Results
WWW.ADVANCEDPHOTONIX.COM
DESCRIPTION
FEATURES
The SD039-121-011 is a high sensitivity, low capacitance and noise, 1mm
diameter active area InGaAs photodiode, sensitive to wavelengths in
visible extended (450-1700nm) spectral range and used sensing
applications. The photodetector is assembled in a TO-46 package.
RELIABILITY
APPLICATIONS
This API high-reliability detector is in principle able to meet military test
requirements (Mil-STD-750, Mil-STD-883) after proper screening and
group test.
Contact API for recommendations on specific test conditions and
procedures.
• Industrial Sensing
• Security and Defense
• Communication
MOISTURE SENSITIVITY LEVEL
ESD
This device is Class 1A (HBM).
API silicon light dependent resistors are classified as MSL level 1 per
J-STD-020 allowing for unlimited floor time at temperatures less than or
equal to 30°C and humidity less than or equal to 85%.
Ta = 23°C non condensing
ABSOLUTE MAXIMUM RATINGS
SYMBOL
Operating Temperature
Storage Temperature
Soldering Temperature *
Wavelength Range
Reverse Voltage
Low Noise
Low Dark Current and Capacitance
High Sensitivity
Light Detection (Visible, NIR, SWIR)
MIN
450
MAX
+85
+85
+240
1700
UNITS
°C
°C
°C
nm
V
*) 1/16 inch from case for 3s max.
Information in this technical datasheet is believed to
be correct and reliable. However, no responsibility is
assumed for possible inaccuracies or omission.
Specifications are subject to change without notice.
REV 8-27-15
Page 1/2
© 2015 Advanced Photonix, Inc. All rights reserved.
Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
InGaAs Photodiode
SD039-121-011
Ta = 23°C unless noted otherwise
OPTO-ELECTRICAL PARAMETERS
PARAMETER
Breakdown Voltage
Responsivity
Responsivity
Responsivity
Shunt Resistance
Dark Current
Capacitance
Rise Time (50Ω load)
Noise Equivalent Power
TEST CONDITIONS
Ibias = 100 µA
λ= 600 nm
λ= 1200 nm
λ= 1550 nm
Vbias = 10 mV
Vbias = 1V
Vbias = 1V; f = 1 MHz
Vbias = 1V; λ= 826 nm
λ= 900 nm
MIN
TYP
MAX
10
0.3
0.8
0.9
0.8
0.35
0.85
1.00
5
5
1.6
100
70
UNITS
V
A/W
A/W
A/W
MΩ
nA
pF
ns
-13
0.5
10 W/Hz
TYPICAL PERFORMANCE
SPECTRAL RESPONSE
1.2
Responsivity, A/W
1
0.8
0.6
0.4
0.2
600
800
1000
1200
1400
1600
1800
Wavelenght, nm
REV 8-27-15
Page 2/2
很抱歉,暂时无法提供与“SD039-121-011”相匹配的价格&库存,您可以联系我们找货
