Filtered SMT Photodiode Assembly
SD 019-141-411 -R
-G
-B
Advanced Photonix, Inc.
FEATURES
Small Footprint
Low Capacitance
High Speed
DESCRIPTION
The SD 019-141-411 is a silicon photodiode assembled
in a 0805 SMT package with an integrated bandpass filter. Three standard wavelength ranges are available.
APPLICATIONS
Industrial Sensors
Light Management
Handheld Devices
ORDERING INFORMATION
PART NUMBER
SD019-141-411 - R
SD019-141-411 - G
SD019-141-411 - B
BAND PASS
RANGE [nm]
Red
Green
Blue
625 – 655
510 – 540
435 – 465
ABSOLUTE MAXIMUM RATING
TYPICAL SPECTRAL RESPONSE
Ta = 25°C UNLESS OTHERWISE NOTED
PARAMETER
Reverse Voltage
Operating Temperature
Storage Temperature
Soldering Temperature*
MIN
MAX
50
-40 +105
-50 +125
+260
UNITS
V
°C
°C
°C
0.18
0.16
Responsivity [A/W]
SYMBOL
VR
TOp
TStg
TS
0.20
0.14
0.12
0.10
0.08
0.06
0.04
0.02
1150
1200
1100
1050
950
1000
900
850
800
750
700
650
600
550
500
450
400
350
300
250
200
0.00
Wavelength [nm]
ELECTRO-OPTICAL CHARACTERISTICS RATING
SYMBOL
Vf
R
CHARACTERISTIC
Forward Voltage
Responsivity (-R)
TEST CONDITIONS
If=10 mA
VR = 0V; λ = 450 nm
Ta= 25°C, UNLESS OTHERWISE NOTED
MIN
0.5
TYP
0.8
0.06
MAX
1.3
UNITS
V
A/W
Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are
subject to change without notice. © 2013 Advanced Photonix, Inc. All rights reserved.
Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 • www.advancedphotonix.com
REV 07/29/14
SD 019-141-411 -R
-G
-B
SYMBOL
R
R
Vbr
Rsh
Id
Cj
tr
CHARACTERISTIC
Responsivity (-G)
Responsivity (-B)
Breakdown Voltage
Shunt Resistance
Dark Current
Junction Capacitance
Rise Time
TEST CONDITIONS
VR = 0V; λ = 550 nm
VR = 0V; λ = 625 nm
IR = 100 µA
Vbias = 10 mV
VR = 10 V
VR = 5V; f = 1000 kHz
VR = 3V; Ri= 1000Ω
MIN
50
TYP
0.12
0.05
2.0
6.0
10
MAX
0.5
UNITS
A/W
A/W
V
GΩ
nA
pF
nS
REV 07/29/14
很抱歉,暂时无法提供与“SD019-141-411-R”相匹配的价格&库存,您可以联系我们找货
