SD019-141-411-G
SD019-141-411-G
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE GREEN MICRO SMT
SD019-141-411-G 数据手册
Filtered SMT Photodiode Assembly SD 019-141-411 -R -G -B Advanced Photonix, Inc. FEATURES • • • Small Footprint Low Capacitance High Speed DESCRIPTION The SD 019-141-411 is a silicon photodiode assembled in a 0805 SMT package with an integrated bandpass filter. Three standard wavelength ranges are available. APPLICATIONS Industrial Sensors Light Management Handheld Devices • • • ORDERING INFORMATION PART NUMBER SD019-141-411 - R SD019-141-411 - G SD019-141-411 - B BAND PASS RANGE [nm] Red Green Blue 625 – 655 510 – 540 435 – 465 ABSOLUTE MAXIMUM RATING TYPICAL SPECTRAL RESPONSE Ta = 25°C UNLESS OTHERWISE NOTED PARAMETER Reverse Voltage Operating Temperature Storage Temperature Soldering Temperature* MIN MAX 50 -40 +105 -50 +125 +260 UNITS V °C °C °C 0.18 0.16 Responsivity [A/W] SYMBOL VR TOp TStg TS 0.20 0.14 0.12 0.10 0.08 0.06 0.04 0.02 1150 1200 1100 1050 950 1000 900 850 800 750 700 650 600 550 500 450 400 350 300 250 200 0.00 Wavelength [nm] ELECTRO-OPTICAL CHARACTERISTICS RATING SYMBOL Vf R CHARACTERISTIC Forward Voltage Responsivity (-R) TEST CONDITIONS If=10 mA VR = 0V; λ = 450 nm Ta= 25°C, UNLESS OTHERWISE NOTED MIN 0.5 - TYP 0.8 0.06 MAX 1.3 - UNITS V A/W Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. © 2013 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 • www.advancedphotonix.com REV 07/29/14 Filtered SMT Photodiode Assembly SD 019-141-411 -R -G -B Advanced Photonix, Inc. ELECTRO-OPTICAL CHARACTERISTICS RATING SYMBOL R R Vbr Rsh Id Cj tr CHARACTERISTIC Responsivity (-G) Responsivity (-B) Breakdown Voltage Shunt Resistance Dark Current Junction Capacitance Rise Time TEST CONDITIONS VR = 0V; λ = 550 nm VR = 0V; λ = 625 nm IR = 100 µA Vbias = 10 mV VR = 10 V VR = 5V; f = 1000 kHz VR = 3V; Ri= 1000Ω Ta= 25°C, UNLESS OTHERWISE NOTED MIN 50 - TYP 0.12 0.05 2.0 6.0 10 MAX 0.5 - UNITS A/W A/W V GΩ nA pF nS Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. © 2013 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 • www.advancedphotonix.com REV 07/29/14
SD019-141-411-G 价格&库存
很抱歉,暂时无法提供与“SD019-141-411-G”相匹配的价格&库存,您可以联系我们找货
