SD002-151-001
SD002-151-001
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE 800-1700NM .05MM 1206
SD002-151-001 数据手册
Surface-Mount InGaAs Photodetector SD002-151-001 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM CHIP DIMENSIONS, µm 1206 PACKAGE DIMENSIONS, mm[inch] DESCRIPTION FEATURES The SD002-151-001 is a high sensitivity, low noise, 0.05 mm diameter active area InGaAs photodiode sensitive to wavelengths over a standard InGaAs (800-1700nm) spectral range and used for imaging and sensing applications. The photodetector is assembled in a 1206 package.     RELIABILITY APPLICATIONS Contact API for recommendations on specific test conditions and procedures.     MAX Reverse Voltage Operating Temperature Storage Temperature Soldering Temperature Wavelength Range 40 +125 +100 +260 1700 Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Industrial Sensing Security Communication Medical Ta = 23°C unless noted otherwise ABSOLUTE MAXIMUM RATINGS SYMBOL MIN -40 -55 800 Low Noise Low Dark Current and Capacitance High Sensitivity Detection in LWIR UNITS V °C °C °C nm REV 11-24-14 Page 1/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 Surface-Mount InGaAs Photodetector SD002-151-001 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM Ta = 23°C unless noted otherwise ABSOLUTE MAXIMUM RATINGS PARAMETER Breakdown Voltage Responsivity Shunt Resistance Dark Current Capacitance Rise Time (50 load) Spectral Range Noise Equivalent Power TEST CONDITIONS MIN Ibias = 1 A = 1310 nm, Vr=5V Vbias = 10 mV Vbias = 5V Vbias = 5V; f = 1.0 MHz Vbias = 5V; = 1310 nm Vr= 5V@ =1310 TYP 0.80 0.2 800 - 50 1.0 1.0 0.75 10 1.2 -15 4.0x10 MAX 1.0 1700 - UNITS V A/W G nA pF ns nm 1/2 W/Hz TYPICAL PERFORMANCE SPECTRAL RESPONSE 0.95 0.85 Responsivity,A/W 0.75 0.65 0.55 0.45 0.35 0.25 0.15 0.05 680 880 1080 1280 1480 1680 Wavelenght, nm Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 11-24-14 Page 2/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
SD002-151-001 价格&库存
很抱歉,暂时无法提供与“SD002-151-001”相匹配的价格&库存,您可以联系我们找货
