SD012-UVC-011
SD012-UVC-011
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE UV 210-280NM TO46
SD012-UVC-011 数据手册
GaN Photodiode SD012-UVC-011 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM DESCRIPTION 2 The SD012-UVC-011 is an AlGaN UVC photodiode with a 0.076 mm active area, hermetically assembled in TO-46 package. Unlike most UV detectors it cuts off unwanted visible light from its detection spectrum (210-280nm), thereby eliminating the need for optical filter. RELIABILITY This API high-reliability detector is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact API for recommendations on specific test conditions and procedures. FEATURES  Schottky-Type Photodiode  Photovoltaic Mode Operation  Low Noise  High Speed  Visible Blindness APPLICATIONS  UVC Detection and Monitoring  Medical  Military ABSOLUTE MAXIMUM RATINGS PARAMETER MIN MAX UNITS Storage Temperature -30 +85 Operating Temperature -40 +125 °C °C Soldering Temperature* - +240 °C Forward Current - 1.0 mA Reverse Voltage - 5.0 V Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 02-01-15 Page 1/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 GaN Photodiode SD012-UVC-011 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM OPTO-ELECTRICAL PARAMETERS PARAMETER TEST CONDITIONS Dark Current Shunt Resistance Short Circuit Current Spectral Application Range Responsivity Peak Capacitance Noise Equivalent Power VR = 0.1V VR = 10 mV UVI=1.0 Spot Scan l= 275 nm V, VR = 0 V V bias = 0V; f = 1 MHz = 350 nm Ta = 23°C unless noted otherwise MIN 1.0 210 - TYP 0.1 100 20 0.06 10 1.6 MAX 100 280 - UNITS pA GW nA nm A/W pF -17 0.5 10 W/Hz TYPICAL PERFORMANCE SPECTRAL RESPONSE NOISE vs. BIAS UV-A PHOTOCURRENT UV-I PHOTOCURRENT Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 02-01-15 Page 2/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
SD012-UVC-011 价格&库存
很抱歉,暂时无法提供与“SD012-UVC-011”相匹配的价格&库存,您可以联系我们找货
