SD012-UVB-011
SD012-UVB-011
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE UV 220-320NM TO46
SD012-UVB-011 数据手册
GaN UV Photodiode SD012-UVB-011 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM DESCRIPTION 2 The SD012-UVB-011 is a GaN UVB photodiode with a 0.076 mm active area. Unlike most UV detectors it cuts off unwanted visible light from its detection spectrum (220-320nm), thereby eliminating the need for optical filter. Photodiode is assembled packaged in a hermetic TO46 package RELIABILITY This API high-reliability detector is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact API for recommendations on specific test conditions and procedures. MIN Storage Temperature Operating Temperature Soldering Temperature* Forward Current Reverse Voltage Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. APPLICATIONS  UVB Detection and Monitoring  Medical  Military Ta = 23°C unless noted ABSOLUTE MAXIMUM RATINGS PARAMETER FEATURES  Schottky-Type Photodiode  Photovoltaic Mode Operation  Low Noise  High Speed  Visible Blindness -30 -40 - MAX +85 +125 +240 1.0 5.0 UNITS °C °C °C mA V REV 01-14-15 Page 1/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 GaN UV Photodiode SD012-UVB-011 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM Ta = 23°C unless noted otherwise OPTO-ELECTRICAL PARAMETERS PARAMETER Dark Current Shunt Resistance Short Circuit Current Spectral Application Range Responsivity Peak Capacitance Noise Equivalent Power TEST CONDITIONS VR = 0.1V VR = 10 mV UVI=1.0 Spot Scan l= 290 nm V, VR = 0 V V bias = 0V; f = 1 MHz = 350 nm MIN 1.0 220 - TYP 0.1 100 20 0.14 10 1.6 MAX 100 370 - UNITS pA GW nA nm A/W pF -17 0.5 10 W/Hz TYPICAL PERFORMANCE UV-A PHOTOCURRENT UV-I PHOTOCURRENT NOISE vs. BIAS SPECTRAL RESPONSE Noise Current (A/rt_Hz) 6.E-14 6.E-15 6.E-16 6.E-17 1.E-02 1.E-01 1.E+00 Reverse Voltage (V) Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 01-14-15 Page 2/2 © 2014 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
SD012-UVB-011 价格&库存
很抱歉,暂时无法提供与“SD012-UVB-011”相匹配的价格&库存,您可以联系我们找货
