SD197-121-041
SD197-121-041
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Photodiode 5ns 82°
SD197-121-041 数据手册
InGaAs Photodiode SD197-121-041 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM DESCRIPTION FEATURES The SD197-121-041 is a high sensitivity, low capacitance and noise, 5mm diameter active area InGaAs photodiode, sensitive to wavelengths in visible extended (450-1700nm) spectral range and used for imaging and sensing applications. The photodetector is assembled in a TO-5 package. .     RELIABILITY APPLICATIONS This API high-reliability detector is in principle able to meet military test requirements (Mil-STD-750, Mil-STD-883) after proper screening and group test. Contact API for recommendations on specific test conditions and procedures.     Low Noise Low Dark Current and Capacitance High Sensitivity Detection in LWIR Industrial Sensing Security and Defense Communication Medical ABSOLUTE MAXIMUM RATINGS SYMBOL Operating Temperature Storage Temperature Soldering Temperature Wavelength Range Reverse Voltage MIN 0 -25 450 - Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. MAX +85 +85 +240 1700 20 UNITS °C °C °C nm V Ta = 23°C non condensing see recommended reflow profile REV 5-14-15 Page 1/2 © 2015 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 InGaAs Photodiode SD197-121-041 Advanced Photonix, Inc. Precision – Control – Results WWW.ADVANCEDPHOTONIX.COM Ta = 23°C unless noted otherwise OPTO-ELECTRICAL PARAMETERS PARAMETER TEST CONDITIONS Breakdown Voltage Responsivity Responsivity Shunt Resistance Dark Current Capacitance Rise Time (50 load) Noise Equivalent Power MIN Ibias = 100 A = 660 nm = 1200 nm Vbias = 10 mV Vbias = 5V Vbias = 0V; f = 1 MHz Vbias = 24V; = 826 nm = 900 nm TYP 10 - 0.35 0.90 30 5 10 MAX 10 100 - UNITS V A/W A/W M nA pF ns -14 0.5 10 W/Hz TYPICAL PERFORMANCE SPECTRAL RESPONSE 0.95 0.85 Responsivity,A/W 0.75 0.65 0.55 0.45 0.35 0.25 0.15 0.05 450 650 850 1050 1250 1450 1650 Wavelenght, nm Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 5-14-15 Page 2/2 © 2015 Advanced Photonix, Inc. All rights reserved. Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
SD197-121-041 价格&库存
很抱歉,暂时无法提供与“SD197-121-041”相匹配的价格&库存,您可以联系我们找货
