PDV-V400
PDV-V400
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    Photodiode 525nm 1µs TO-5
PDV-V400 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photovoltaic (photopic response) Type PDV-V400 DETECTORS INC. EPOXY COVERING EYELET PACKAGE DIMENSIONS INCH [mm] WIRE BONDS EPOXY MARKING INK "V400" ACTIVE AREA SURFACE +- 0.005 [0.13] 0.080 [2.03] 0.200 [5.08] DIA PIN CIRCLE 0.365 [9.27] 0.355 [9.02]DIA 0.345 [8.76] 0.335 [8.51] 0.245 [6.22] 0.235 [5.97] DIA 0.500 [12.70] CHIP 0.330 [8.38] 0.320 [8.13] DIA FILTER CAP SUBASSEMBLY 45° 0.020 [0.51] DIA 2 PLACES 0.035 [0.89] 0.030 [0.76] ANODE CATHODE (CASE GROUND) HEADER 0.425 [10.80] 0.415 [10.54] ACTIVE AREA 0.223 [5.66] 0.123 [3.12] ACTIVE AREA 0.135 [3.43] TO-5 CAN PACKAGE 0.235 [5.97] ACTIVE AREA = 17.74 mm2 FEATURES Large active area High transmission Low noise DESCRIPTION The PDV-V400 is a silicon, PIN planar diffused, photodiode with a photopic response filter. The detector filter combination has a wide bandwidth designed to simulate the spectral response of the human eye. Packaged in a TO-5 metal can. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS O TS Soldering Temperature* +240 O IL Light Current 0.5 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ 150 MAX mA 200 10 UNITS 50 pA 2 GΩ H = 0, V R = 10 mV -8 % / oC Junction Capacitance H = 0, VR = 10 V** 1700 pF CWL Center Wavelength (CWL, l o) +/- 2 nm 525 nm HBW Half Bandwidth (FWHM) 150 nm V BR Breakdown Voltage I = 10 m A 75 V RSH NEP tr 1200 +70 1100 -15 900 Operating Temperature Range 1000 TO C 800 O 0% 700 +85 0 =1 QE 0.4 600 -20 0.5 500 Storage Temperature TSTG 0.6 400 V 300 100 190 Reverse Voltage SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) V BR APPLICATIONS Photometry Radiometry Film color processing Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 10 V .20 50 -15 9x10 1.0 W/ Hz µS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDV-V400 REV C]
PDV-V400 价格&库存
很抱歉,暂时无法提供与“PDV-V400”相匹配的价格&库存,您可以联系我们找货
