PDI-M301
PDI-M301
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    Photodiode 900nm 11ns 84° TO-5
PDI-M301 数据手册
PHOTONIC DETECTORS INC. 1.06 Micron, High Speed Silicon Photodiode Type PDI-M301 PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.130 [3.30] 0.075 [1.91] 0.030 [0.76] C L 0.500 [12.70] MIN 45° GUARD RING C L 84° C L VIEWING ANGLE 0.200 [5.08] 0.035 [0.89] RL CL HEADER PHOTODIODE 0.142 [3.61] SQ Ø0.099 [Ø2.52] SIGNAL Ø0.358 [9.09] SENSITIVE AREA + CATHODE Ø0.018 [0.46] GUARD RING Ø0.018 [0.46] ANODE Ø0.018 [0.46] ACTIVE AREA GUARD RING TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 5.0 mm2 FEATURES .45 A/W @1060 nm 11 ns response time Low noise +100 O TS Soldering Temperature* +260 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP UNITS mA Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 200 V 9 Shunt Resistance H = 0, V R = 10 mV 100 MΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -10 % / oC CJ Junction Capacitance H = 0, V R = 200 V** 2.8 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 1 mA NEP tr 40 MAX ISC RSH 1200 -40 1100 Operating Temperature Range 0.4 900 TO C 1000 O 800 +125 700 -55 % 00 =1 QE 0.5 600 Storage Temperature 0.6 500 TSTG 500 V 0.7 400 75 SPECTRAL RESPONSE 300 Reverse Voltage Optical pyrometer sensor 190 VBR APPLICATIONS YAG laser detection High speed IR sensor RESPONSIVITY (A/W) DESCRIPTION The PDI-M301 is a high speed photodiode, processed on high resistivity P type silicon. Guard ring construction for enhanced 1060 nm response and 28 Mhz bandwidth. Packaged in a 3 leaded hermetic TO-5 hermetic package. Ideal for Nd YAG laser. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS 60 16 400 900 250 nA 3.0 pF 1150 nm nm 400 V -12 Noise Equivalent Power VR = 10 V @ 900 nm 1.5x10 Response Time RL = 1 KΩ VR = 200 V 11 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDI-M301 REV C]
PDI-M301
物料型号:PDI-M301
器件简介: - PDI-M301是一款高速光电二极管,采用高电阻率P型硅制成。 - 具有增强的1060纳米响应和28兆赫兹带宽的保护环结构。 - 封装在3引脚的TO-5密封封装中。 - 适用于Nd YAG激光。
引脚分配: - 阳极(ANODE) - 阴极(CATHODE) - 保护环(GUARD RING)
参数特性: - 反向电压(V BR):最大75V - 存储温度(TSTG):-55℃至+125℃ - 工作温度范围(T。):-40℃至+100℃ - 焊接温度(Ts):最大+260℃ - 光电流:最大500mA
功能详解: - 短路电流(5c):在100 fc, 2850K条件下,最小值为40mA - 暗电流(1):在0光强度,200V反向电压下,典型值为9nA - 并联电阻(Rg):在0光强度,10mV反向电压下,典型值为100MΩ - 并联电阻温度系数(TCRg):在0光强度,10mV反向电压下,典型值为-10% - 结电容(CJ):在0光强度,200V反向电压下,典型值为2.8pF - 光谱应用范围(Arange):在点扫描下,400nm至1150nm - 光谱响应峰值(Ap):在点扫描下,典型值为900nm - 击穿电压(V田):在1A电流下,典型值为250V至400V - 噪声等效功率(NEP):在10V@ 900nm下,典型值为1.5x10^-12 W/Hz - 响应时间(tr):在1kΩ负载,200V电压下,典型值为11ns
应用信息: - YAG激光检测 - 高速红外传感器 - 光学高温计传感器
封装信息: - 封装类型:TO-5密封封装 - 封装尺寸:0.130英寸(3.30毫米)直径,窗口帽(焊接)0.030英寸(0.76毫米)直径,保护环敏感区域0.075英寸(1.91毫米)直径,视场角度84°,信号引脚直径0.035英寸(0.89毫米),阴极直径0.018英寸(0.46毫米),阳极直径0.018英寸(0.46毫米),活动区域0.142平方英寸(3.61平方毫米)。
PDI-M301 价格&库存
很抱歉,暂时无法提供与“PDI-M301”相匹配的价格&库存,您可以联系我们找货
