PDB-C106
PDB-C106
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    Photodiode 950nm 18ns 55° TO-5
PDB-C106 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C106 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) 0.030 [0.76] Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.075 [1.91] WIRE BONDS CL 0.500 [12.70] MIN 45° Ø0.358 [9.09] 55° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.154 [3.91] SQ Ø0.1404 [Ø3.567] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 10.00 mm2 APPLICATIONS DESCRIPTION The PDB-C106 is a silicon, PIN planar Instrumentation diffused, blue enhanced photodiode. Ideal Analytical measurements for high speed photoconductive applications. Laser sensor Packaged in a hermetic TO-5 metal can Industrial sensor with a flat window. Light Current O 500 C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 IL +240 C 0.3 1100 Soldering Temperature* +125 0.4 900 TS -40 O C 1000 Operating Temperature Range O 0% 800 TO +150 0 =1 QE 700 -55 0.5 600 Storage Temperature V 500 TSTG 100 0.6 400 Reverse Voltage 0.7 300 V BR SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 100 MAX mA 130 2 UNITS 10 nA 650 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 10 V** 70 pF Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V 200 350 75 1100 nm 950 nm 100 V -14 3x10 18 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDB-C106 REV C]
PDB-C106 价格&库存
很抱歉,暂时无法提供与“PDB-C106”相匹配的价格&库存,您可以联系我们找货
