PHOTONIC
DETECTORS INC.
Detector Amplifier Hybrid, Blue Enhanced
Type PDB-711-10
PACKAGE DIMENSIONS INCH [mm]
INDUSTRY EQUIVALENT:
OSI 5-10M/10K
WINDOW CAP (WELDED)
ACTIVE AREA SURFACE
.090 [2.29] ±.005 [0.13]
.085 [2.15]
.075 [1.90]
Ø.200 [5.08]
PIN CIRCLE
PIN 5. CASE SHIELD
.500 [12.70]
PIN 4. V+
PIN 1.
CIRCUIT
GROUND
PIN 3. V-
82°
VIEWING
ANGLE
Ø.330 [8.38]
Ø.320 [8.13]
Ø.20 [0.50]
5 PLACES
.035 [0.89]
.030 [0.76]
FLANGE
.175 [4.44]
.165 [4.19]
.110 [2.79] SQ
.090 [2.29]
ACTIVE AREA
Ø.365 [Ø9.27]
Ø.355 [Ø9.02]
PIN 2. OUTPUT
TO-5 HERMETIC CAN PACKAGE
CAUTION: ESD SENSITIVE DEVICE
.090 [2.29]
ACTIVE AREA
ACTIVE AREA = 5.09 mm2
APPLICATIONS
Medical diagnostic
Low signal
applications
Color analysis
Analytical chemistry
SPECTRAL RESPONSE
DESCRIPTION: The PDB-711-10 is a low
noise, medium speed, blue enhanced silicon
photodiode integrated with a low noise JFET
monolithic transimpedance op-amp. There is
an internal 10 MOhm feedback gain resistor which limits the bandwidth to 10KHz.
Light Current
O
500
C
mA
0.2
0.1
IL
+240
C
0.3
1100
Soldering Temperature*
900
TS
+70
O
C
1000
Operating Temperature Range
O
0%
800
TO
+125
=1
QE
700
-55
0.5
600
Storage Temperature
V
500
TSTG
15
400
Reverse Voltage
0.6
300
V BR
0.7
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
RESPONSIVITY (A/W)
FEATURES
10 Khz bandwidth
Internal10 MOhm gain
Low offset voltage
Low input bias current
WAVELENGTH (nm)
*1/16 inch from case for 3 secs max
PHOTODIODE ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
MAX
UNITS
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
λrange
λp
V BR
NEP
tr
45
mA
65
1.0
5.0
nA
2
GΩ
H = 0, V R = 10 mV
-8
% / oC
H = 0, V R = 10 V**
15
pF
Spectral Application Range Spot Scan
Spectral Response - Peak
Spot Scan
Breakdown Voltage
I = 10 m A
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 10 V
.5
350
1100
950
100
nm
125
2.5x10
15
nm
V
-14
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. ** f = 1 MHz
PAGE 1 OF 2
[FORM NO. 100-PDB-711-10 REV A]
PHOTONIC
DETECTORS INC.
AMPLIFIER SPECIFICATION
Type PDB-711-10
TA = 25° C and VS =± 15 vdc
UNLESS OTHERWISE NOTED
CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
FEEDBACK NETWORK 10
MEG Ω RESISTER, 1pF*
CAPACITOR
THIN FILM RESISTOR
TRIMMED TO ±5%
*TOL ±5%
10
INITIAL OFFSET
0.75
LONG TERM OFFSET STABILITY
15
OFFSET CURRENT, VCM=0
5
DIFFERENTIAL
1 X 10-12 3
COMMONMODE
1 X 10-12 3
MAX
UNITS
MEG Ω
2.0
mV
INPUT OFFSET VOLTAGE
INPUT BIAS CURRENT
µV/MONTH
Ω pF
INPUT IMPEDANCE
COMMONMODE
INPUT VOLTAGE RANGE
COMMONMODE
REJECTION VCM ±10 V
±11
±12
76
90
pA
V
VOLTAGE 0, 1 Hz TO 10 Hz
2
µV p-p
VOLTAGE 0, f=10 Khz
30
nV/√Hz
f=1 Khz
1.8
fA / √Hz
INPUT VOLTAGE NOISE
INPUT CURRENT NOISE
UNITY GAIN, SMALL SIGNAL
0.8
1.0
MHz
SLEW RATE, UNITY GAIN
1.0
1.8
V/µs
vo= ±10 V, RL=10 KΩ
300
1000
V/mV
VOLTAGE @ RL=10 K Ω
±12
±13
V
VOLTAGE @ RL>5 K Ω
±11
±12.3
V
OPERATING RANGE
±4.5
±15
FREQUENCY RESPONSE
OPEN LOOP GAIN
OUTPUT CHARACTERISTICS
POWER SUPPLY
±18
V
AMPLIFIER ABSOLUTE MAXIMUM RATING (TA=25°C UNLESS OTHERWISE NOTED)
10 MOhm
PARAMETER
MIN
MAX
UNITS
SUPPLY VOLTAGE
±4.5
±18
V
INTERNAL POWER DISSIPATION
STORAGETEMPERATURE
OPERATINGTEMPERATURE
-55
mW
+150
°C
+70
°C
PIN 5
CASE SHIELD
1 pF
PIN 4
V+
5.09 mm2
PHOTODIODE
OP
AMP
PIN 1
CIRCUIT
GROUND
PIN 2
OUTPUT
PIN 3
V-
PAGE 2 OF 2
很抱歉,暂时无法提供与“PDB-711-10”相匹配的价格&库存,您可以联系我们找货
