PDV-V417
PDV-V417
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Through Hole
    PHOTODIODE PIN 5.44MM SQ CERAMIC
PDV-V417 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Visible Light Detector Type PDV-V417 PACKAGE DIMENSIONS INCH [mm] 0.071 [1.80] 0.236 [6.00] ANODE Ø0.018 [0.45] 2 PLACES 0.138 [3.50] CL 0.193 [4.90] Ø0.315 [8.00] 100° VIEWING ANGLE 0.197 [5.00] CATHODE CL VISIBLE PASS I.R. BLOCKING FILTER 0.354 [9.00] HOLE INDICATES CATHODE 0.099 [2.51] 0.085 [2.16] ACTIVE AREA 0.100 [2.54] ACTIVE AREA 0.115 [2.92] CERAMIC PACKAGE ACTIVE AREA = 5.44 mm2 DESCRIPTION The PDV-V417 is a silicon PIN photodiode, with a built in visible pass, I.R. blocking optical filter. Housed in a black ceramic package with two leads. Designed for photovoltaic operation with 0 volt bias. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 1 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ UNITS mA 6.5 1.0 1.5 GΩ H = 0, VR = 10 mV -8 % / oC Junction Capacitance H = 0, VR = 0 V** 650 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr H = 100 fc, 2850 K MAX 5 RSH 12 00 IL +240 C % 11 00 Soldering Temperature* +60 C 00 10 00 TS -20 O =1 80 0 Operating Temperature Range O QE 0.4 90 0 TO +80 0.5 60 0 -20 0.6 70 0 Storage Temperature V 40 0 10 50 0 TSTG Reverse Voltage 19 0 V BR SPECTRAL RESPONSE 0.7 30 0 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Camera exposure meter Light meters Visible detector RESPONSIVITY (A/W) FEATURES Visible response Low dark current Good linearity Low noise 3 320 730 560 10 10 pA nm nm 15 5x10-14 500 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDV-V417 REV A]
PDV-V417 价格&库存
很抱歉,暂时无法提供与“PDV-V417”相匹配的价格&库存,您可以联系我们找货
