PHOTONIC
Silicon Photodiode, Blue Enhanced Solderable Chips
Photoconductive Type PDB-C604 Photovoltaic Type PDB-V604
DETECTORS INC.
PACKAGE DIMENSIONS INCH (mm)
0.197 [5.00]
0.197 [5.00]
0.197 [5.00]
1.00 [25.4]
1.250 [6.35]
0.030 [0.76]
0.047 [1.19]
0.047 [1.19]
0.047 [1.19]
ANODE, BUSS W IRE
ANODE, RED W IRE
0.016 [0.41]
0.014 [0.36]
0.016 [0.41]
0.014 [0.36]
0.016 [0.41]
0.014 [0.36]
C ATHODE, BLACK W IRE
30 GAGE P.V.C. WIRE
34 GAGE BUSS WIRE
PDB-C604-2
PDB-V604-2
PDB-C604-3
PDB-V604-3
V
-40 +125 -40 +125
O
TO
Operating Temperature Range -40 +100 -40 +100
O
TS
Soldering Temperature
+224
+224
O
IL
Light Current
500
500
TSTG
Storage Temperature
ELECTRO-OPTICAL CHARACTERISTICS
SYMBOL CHARACTERISTIC
TEST CONDITIONS
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 5 V*
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
H = 0, VR = 10 mV
CJ
Junction Capacitance
H = 0, VR = 5 V**
λrange
Spectral Application Range Spot Scan
λp
Spectral Response - Peak Spot Scan
V BR
Breakdown Voltage
NEP
tr
C
C
0.4
=1
00
0.3
0.2
0.1
mA
WAVELENGTH (nm)
(TA=25OC unless otherwise noted)
ISC
RSH
C
QE
1200
75
0.5
1000
25
0.6
1100
UNITS
MAX
800
Reverse Voltage
MIN
900
V BR
MAX
SPECTRAL RESPONSE
0.7
600
MIN
Optical encoder
Position sensor
Industrial controls
Instrumentation
190
PARAMETER
PDB-C604 PDB-V604
RESPONSIVITY (A/W)
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
APPLICATIONS
DESCRIPTION: Low cost blue enhanced planar diffused
silicon solderable photodiode. The PDB-V604 cell is designed
for low noise, photovoltaic applications. The PDB-C604 cell is
designed for low capacitance, high speed, photoconductive
operation. They are available bare, PVC or buss wire leads.
400
Blue enhanced
Photovoltaic type
Photoconductive type
High quantum efficiency
300
FEATURES
700
ACTIVE AREA = 4.34 mm2
PDB-C604-1
PDB-V604-1
500
BARE CHIP
I = 10 mA
Noise Equivalent Power
VR = 0 V @ Peak
Response Time
RL = 1 KΩ VR = 5 V**
PDB-C604
PDB-V604
MIN TYP MAX MIN TYP MAX
50
68
6
12
45
10
30
30
50
MΩ
% / oC
350
8 x 10
-14
15
5
TYP
nA
-8
600
1100
940
25
25
50
-8
350
mA
58
12
UNITS
pF
1100
nm
940
nm
15
V
6 x 10
-14
500
TYP
W/
Hz
nS
*VR = 100 mV on Photovoltaic type
**VR = 0 V on Photovoltaic type
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.
[FORM NO. 100-PDB-C604-V604 REV B]
很抱歉,暂时无法提供与“PDB-C604-2”相匹配的价格&库存,您可以联系我们找货
