PDB-C601-3
PDB-C601-3
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    芯片,带34线规BUSS导线
    PHOTODIODE BLUE 1MM SQ BUSS WIRE
PDB-C601-3 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Solderable Chips Photoconductive Type PDB-C601 Photovoltaic Type PDB-V601 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) 0 .1 2 5 [3 .1 8 ] 0 .1 2 5 [3 .1 8 ] 0 .1 2 5 [3 .1 8 ] 1 .0 0 [2 5 .4 ] 1 .2 5 0 [6 .3 5 ] 0 .0 5 0 [1 .2 7 ] 0 .0 3 0 [0 .7 6 ] 0 .0 3 0 [0 .7 6 ] 0 .0 3 0 [0 .7 6 ] A N O D E , B U S S W IR E A N O D E , R E D W IR E 0 .0 1 6 [0 .4 1 ] 0 .0 1 4 [0 .3 6 ] 0 .0 1 6 [0 .4 1 ] 0 .0 1 4 [0 .3 6 ] 0 .0 1 6 [0 .4 1 ] 0 .0 1 4 [0 .3 6 ] C A T H O D E , B L A C K W IR E 34 GAGE BUSS WIRE ACTIVE AREA = 1.0 mm2 PDB-C601-1 PDB-V601-1 PDB-C601-2 PDB-V601-2 PDB-C601-3 PDB-V601-3 Operating Temperature Range -40 +100 -40 +100 O TS Soldering Temperature +224 +224 O IL Light Current 500 500 TO ELECTRO-OPTICAL CHARACTERISTICS SYMBOL CHARACTERISTIC TEST CONDITIONS Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V* Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient H = 0, VR = 10 mV CJ Junction Capacitance H = 0, VR = 5 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage N EP tr C C 0.2 0.1 0 mA WAVELENGTH (nm) (TA=25OC unless otherwise noted) ISC RSH C 0.3 1200 O Storage Temperature % 1100 -40 +125 -40 +125 TSTG QE 0.4 00 900 V =1 1000 25 0.5 800 75 0.6 700 UNITS MAX 600 Reverse Voltage MIN 500 V BR MAX 400 MIN 0.7 RESPONSIVITY (A/W) PARAMETER PDB-C601 PDB-V601 Optical encoder Position sensor Industrial controls Instrumentation SPECTRAL RESPONSE ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL APPLICATIONS DESCRIPTION: Low cost blue enhanced planar diffused silicon solderable photodiode. The PDB-V601 cell is designed for low noise, photovoltaic applications. The PDB-C601 cell is designed for low capacitance, high speed, photoconductive operation. They are available bare, PVC or buss wire leads. 300 Blue enhanced Photovoltaic type Photoconductive type High quantum efficiency 30 GAGE P.V.C. WIRE 190 FEATURES BARE CHIP I = 10 mA Noise Equivalent Power VR = 0 V @ Peak Response Time RL = 1 KΩ VR = 5 V** PDB-C601 PDB-V601 MIN TYP MAX MIN TYP MAX 15 17 .5 60 10 150 3 100 10 50 MΩ % / oC 350 -14 1 x 10 10 5 TYP nA -8 250 1100 940 25 7 250 -8 350 mA 13 2 UNITS pF 1100 nm 940 nm 15 V 2 x 10 -14 300 TYP W/ Hz nS *VR = 100 mV on Photovoltaic type **VR = 0 V on Photovoltaic type Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDB-C601-V601REV A]
PDB-C601-3 价格&库存
很抱歉,暂时无法提供与“PDB-C601-3”相匹配的价格&库存,您可以联系我们找货
