PDB-C609-1
PDB-C609-1
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    模具
    PHOTODIODE BLUE 42.4MM SQ BARE
PDB-C609-1 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Solderable Chips Photoconductive Type PDB-C609 Photovoltaic Type PDB-V609 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) 0.284 [7.21] SQ 1.00 [25.4] 0.284 [7.21] SQ 0.284 [7.21] SQ 1.250 [31.75] 0.030 [0.76] ANODE, BUSS WIRE ANODE, RED WIRE CATHODE, BLACK WIRE 30 GAGE BUSS WIRE PDB-C609 -2 PDB-V609-2 PDB-C609-3 PDB-V609-3 -40 +125 -40 +125 O Operating Temperature Range -40 +100 -40 +100 O TS Soldering Temperature +224 +224 O Il Light Current 500 500 TSTG TO Storage Temperature ELECTRO-OPTICAL CHARACTERISTICS SYMBOL CHARACTERISTIC TEST CONDITIONS Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V* Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient H = 0, VR = 10 mV CJ Junction Capacitance H = 0, VR = 5 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage N EP tr C C % 0.3 0.2 0.1 0 mA WAVELENGTH (nm) (TA=25OC unless otherwise noted) ISC RSH C QE 0.4 00 1100 V =1 900 25 0.5 1000 75 0.6 800 UNITS MAX 700 Reverse Voltage MIN 600 V BR MAX SPECTRAL RESPONSE 0.7 400 MIN Optical encoder Position sensor Industrial controls Instrumentation 190 PARAMETER PDB-C609 PDB-V609 RESPONSIVITY (A/W) ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL APPLICATIONS DESCRIPTION: Low cost blue enhanced planar diffused silicon solderable photodiode. The PDB-V609 cell is designed for low noise, photovoltaic applications. The PDB-C609 cell is designed for low capacitance, high speed, photoconductive operation. They are available bare, PVC or buss wire leads. 300 Blue enhanced Photovoltaic type Photoconductive type High quantum efficiency 30 GAGE P.V.C. WIRE 500 BARE CHIP ACTIVE AREA = 42.4 mm2 PDB-C609-1 PDB-V609-1 FEATURES 0.016 [0.41] 0.014 [0.36] 0.016 [0.41] 0.014 [0.36] 1200 0.016 [0.41] 0.014 [0.36] I = 10 mA Noise Equivalent Power VR = 0 V @ Peak Response Time RL = 1 KΩ VR = 5 V** PDB-C609 PDB-V609 MIN TYP MAX MIN TYP MAX 490 545 30 3 490 75 10 5 240 350 50 4 x 10 -13 30 100 MΩ -8 % / oC 350 5 TYP nA 15 5500 1100 940 25 mA 545 50 -8 UNITS pF 1100 nm 940 nm 15 V 1.2 x 10 -13 1500 TYP W/ Hz nS *VR = 100 mV on Photovoltaic type **VR = 0 V on Photovoltaic type Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDB-C609-V609REV A]
PDB-C609-1 价格&库存
很抱歉,暂时无法提供与“PDB-C609-1”相匹配的价格&库存,您可以联系我们找货
