PHOTONIC
Silicon Photodiode, Blue Enhanced Solderable Chips
Photoconductive Type PDB-C610 Photovoltaic Type PDB-V610
DETECTORS INC.
PACKAGE DIMENSIONS INCH (mm)
0.797 [20.24]
0.797 [20.24]
0.797 [20.24]
1.250 [31.75]
1.00 [25.4]
0.029 [0.74]
0.097 [2.46]
0.097 [2.46]
0.097 [2.46]
ANODE, RED WIRE
ANODE, BUSS WIRE
CATHODE, BLACK WIRE
0.016 [0.41]
0.014 [0.36]
30 GAGE P.V.C. WIRE
30 GAGE BUSS WIRE
PDB-C610-2
PDB-V610-2
PDB-C610-3
PDB-V610-3
25
V
-40 +125 -40 +125
O
Operating Temperature Range -40 +100 -40 +100
O
TS
Soldering Temperature
+224
+224
O
IL
Light Current
500
500
TSTG
TO
Storage Temperature
ELECTRO-OPTICAL CHARACTERISTICS
SYMBOL CHARACTERISTIC
TEST CONDITIONS
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 5 V*
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
H = 0, VR = 10 mV
CJ
Junction Capacitance
H = 0, VR = 5 V**
λrange
Spectral Application Range Spot Scan
λp
Spectral Response - Peak Spot Scan
V BR
Breakdown Voltage
N EP
tr
C
C
QE
0.4
=1
00
0.3
0.2
0.1
mA
WAVELENGTH (nm)
(TA=25OC unless otherwise noted)
ISC
RSH
C
0.5
1100
75
0.6
900
UNITS
MAX
1000
Reverse Voltage
MIN
800
V BR
MAX
600
MIN
0.7
400
PARAMETER
SPECTRAL RESPONSE
PDB-C610 PDB-V610
Optical encoder
Position sensor
Industrial controls
Instrumentation
190
ABSOLUTE MAXIMUM RATING
SYMBOL
APPLICATIONS
DESCRIPTION: Low cost blue enhanced planar diffused
silicon solderable photdiode. The PDB-V610 cell is designed
for low noise, photovoltaic applications. The PDB-C610 cell is
designed for low capacitance, high speed, photoconductive
operation. They are available bare, PVC or buss wire leads.
300
Blue enhanced
Photovoltaic type
Photoconductive type
High quantum efficiency
RESPONSIVITY (A/W)
FEATURES
700
ACTIVE AREA = 29.5 mm2
PDB-C610-1
PDB-V610-1
500
BARE CHIP
0.016 [0.41]
0.014 [0.36]
1200
0.016 [0.41]
0.014 [0.36]
I = 10 mA
Noise Equivalent Power
VR = 0 V @ Peak
Response Time
RL = 1 KΩ VR = 5 V**
PDB-C610
PDB-V610
MIN TYP MAX MIN TYP MAX
325
365
325
40
12
10
200
350
50
4.5 x 10
-13
26
40
MΩ
-8
% / oC
350
5
TYP
nA
25
5000
1100
940
25
mA
365
UNITS
pF
1100
nm
940
nm
15
V
1.2 x 10
-13
1200
TYP
W/
Hz
nS
*VR = 100 mV on Photovoltaic type
**VR = 0 V on Photovoltaic type
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.
[FORM NO. 100-PDB-C610-V610 REV A]
很抱歉,暂时无法提供与“PDB-C610-3”相匹配的价格&库存,您可以联系我们找货
