PDB-C101
PDB-C101
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE BLUE 0.31MM SQ TO-46
PDB-C101 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C101 DETECTORS INC. PACKAGE DIMENSIONS inch [mm] WINDOW CAP (WELDED) Ø0.184[4.67] 0.150[3.81] 0.040[1.02] Ø0.155[3.94] 0.060[1.52] WIRE BONDS CL 0.500 [12.70] MIN 45° CL Ø0.210[5.33] CL 0.100[2.54] CL 74° VIEWING ANGLE 0.042 [1.06] ANODE Ø0.018[0.46] HEADER PHOTODIODE CATHODE & CASE Ø0.018[0.46] 0.053[1.35] SQUARE Ø0.0247[Ø0.627] ACTIVE AREA TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 0.31 mm2 DESCRIPTION The PDB-C101 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-46 metal can with a flat window. Soldering Temperature* IL Light Current +125 +240 O 0.5 C C C mA 0.2 0.1 0 WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC SYMBOL CHARACTERISTIC TEST CONDITIONS ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance unless otherwise noted) MIN TYP 3.2 4.6 40 MAX UNITS mA 150 pA 5 GW H = 0, VR = 10 mV -8 % / oC H = 0, V R = 10 V** 15 pF l range Spectral Application Range Spot Scan lp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 mA Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KW VR = 50 V tr % 0.3 *1/16 inch from case for 3 secs max NEP 00 1200 TS -40 O =1 1000 Operating Temperature Range O QE 0.4 1100 TO +150 0.5 800 -55 0.6 900 Storage Temperature V 600 100 700 Reverse Voltage UNITS 400 MAX 500 TSTG MIN 0.7 190 VBR SPECTRAL RESPONSE (TA=25OC unless otherwise noted) 300 ABSOLUTE MAXIMUM RATING SYMBOL PARAMETER APPLICATIONS Instrumentation Industrial controls Laser detection Particle detection RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current .50 350 1100 950 100 125 nm nm V 1.5x10-14 W/ Hz 10 nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1MHz [FORM NO. 100-PDB-C101 REV B]
PDB-C101 价格&库存
很抱歉,暂时无法提供与“PDB-C101”相匹配的价格&库存,您可以联系我们找货
