PHOTONIC
Silicon Photodiode, Blue Enhanced Photoconductive
Type PDB-C102
DETECTORS INC.
PACKAGE DIMENSIONS INCH [mm]
WINDOW CAP
(WELDED)
Ø0.184[4.67]
0.150[3.81]
0.040[1.02]
Ø0.155[3.94]
0.060[1.52]
WIRE
BONDS
C
L
0.500
[12.70]
MIN
45°
C
L
Ø0.210[5.33]
PHOTODIODE
CL
0.100[2.54]
CL
72°
VIEWING
ANGLE
0.042
[1.06]
ANODE
Ø0.018[0.46]
HEADER
CATHODE
Ø0.018[0.46]
0.053[1.35] SQUARE
0.030[0.76] ACTIVE AREA
TO-46 HERMETIC CAN PACKAGE
0.045[1.14] ACTIVE AREA
ACTIVE AREA = .87 mm2
DESCRIPTION
The PDB-C102 is a silicon, PIN planar
diffused, blue enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a hermetic TO-46 metal can
with a flat window.
Light Current
O
0.5
C
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 10 V
RSH
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
8.5
MAX
45
UNITS
mA
9
150
pA
2
GΩ
H = 0, VR = 10 mV
-8
% / oC
H = 0, VR = 10 V**
4
pF
λrange
Spectral Application Range
Spot Scan
λp
Spectral Response - Peak
Spot Scan
VBR
Breakdown Voltage
I = 10 mA
N EP
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 50 V
tr
1200
IL
+240
C
1000
Soldering Temperature*
+125
C
1100
TS
-40
O
800
Operating Temperature Range
O
0.4
900
TO
+150
00
=1
QE
0.5
600
-55
0.6
700
Storage Temperature
V
400
100
500
TSTG
Reverse Voltage
190
VBR
SPECTRAL RESPONSE
0.7
300
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Instrumentation
Character recognition
Laser detection
Fiber optic
RESPONSIVITY (A/W)
FEATURES
High speed
Low capacitance
Blue enhanced
Low dark current
0.5
350
1100
950
100
nm
nm
125
10x10-14
3.0
V
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
[FORM NO. 100-PDB-C102 REV B]
are subject to change without notice. ** f = 1 MHz
很抱歉,暂时无法提供与“PDB-C102”相匹配的价格&库存,您可以联系我们找货
