PDB-C101-I
PDB-C101-I
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO18-3
    PHOTODIODE BLUE 0.31MM SQ TO-18
PDB-C101-I 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Isolated Type PDB-C101-I DETECTORS INC. PACKAGE DIMENSIONS inch [mm] Ø0.184 [4.67] WINDOW CAP (WELDED) Ø0.155 [3.94] 0.198 [5.03] 0.125 [3.18] WIRE BONDS 0.500 [12.70] MIN Ø0.100 B.C. PHOTODIODE CHIP C L Ø0.210 [5.33] 45° 0.040 [1.02] C L 0.042 [1.06] CASE GROUND CATHODE HEADER ANODE Ø0.019 [0.48] 3 PLACES Ø0.016 [0.41] 0.053 [1.35] SQUARE Ø0.0247 [Ø0.627] ACTIVE AREA TO-18 HERMETIC CAN PACKAGE ACTIVE AREA = 0.31 mm2 DESCRIPTION The PDB-C101-I is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-18 metal can with a flat window and isolated ground lead. TO Operating Temperature Range -40 +125 O C TS Soldering Temperature* +240 O C IL Light Current 0.5 mA 0.4 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V RSH Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 10 V** l range Spectral Application Range Spot Scan lp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A NEP tr Noise Equivalent Power V R = 10 V @ Peak Response Time RL = 1 KW V R = 50 V 3.2 150 pA 5 GW W -8 % / oC 15 pF 350 1100 950 100 UNITS mA 4.6 40 .50 MAX nm 125 V -14 1.5x10 10 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1MHz 1200 C 1100 O 0% 10 900 +150 = 1000 -55 QE 800 Storage Temperature 0.5 700 TSTG 0.6 600 V 500 100 400 Reverse Voltage 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Industrial controls Laser detection Particle detection RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current
PDB-C101-I 价格&库存
很抱歉,暂时无法提供与“PDB-C101-I”相匹配的价格&库存,您可以联系我们找货
