PHOTONIC
Silicon Photodiode, Blue Enhanced Photoconductive
Isolated Type PDB-C102-I
DETECTORS INC.
PACKAGE DIMENSIONS INCH [mm]
Ø0.184 [4.67]
WINDOW CAP
(WELDED)
Ø0.155 [3.94]
0.198 [5.03]
0.125 [3.18]
WIRE BONDS
0.500
[12.70]
MIN
Ø0.100 B.C.
PHOTODIODE CHIP
Ø0.210 [5.33]
CL
45°
0.040 [1.02]
CL
0.042 [1.06]
Ø0.019 [0.48]
3 PLACES
Ø0.016 [0.41]
CASE GROUND
CATHODE
HEADER
ANODE
0.053 [1.35]
0.030 [0.76] ACTIVE
AREA
TO-18 HERMETIC CAN PACKAGE
0.045 [1.14] ACTIVE AREA
ACTIVE AREA = .87 mm2
DESCRIPTION
The PDB-C102-I is a silicon, PIN planar
diffused, blue enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a hermetic TO-18 metal can
with a flat window and isolated ground lead.
Operating Temperature Range
-40
+125
O
C
+240
O
C
TS
Soldering Temperature*
IL
Light Current
0.5
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
O
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 V
RSH
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
H = 0, V R = 10 mV
CJ
Junction Capacitance
H = 0, V R = 10 V**
λrange
Spectral Application Range Spot Scan
λp
Spectral Response - Peak
Spot Scan
V BR
Breakdown Voltage
I = 10 m A
N EP
tr
Noise Equivalent Power
V R = 10 V @ Peak
Response Time
RL = 1 KΩ V R = 50 V
8.5
150
pA
2
GΩ
-8
% / oC
4
pF
350
1100
950
100
UNITS
mA
9
45
0.5
MAX
nm
125
10x10
3.0
nm
V
-14
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. ** f = 1 MHz
1200
C
TO
1100
O
900
+150
1000
-55
0.4
800
Storage Temperature
00
=1
QE
0.5
700
TSTG
0.6
600
V
500
100
400
Reverse Voltage
0.7
300
V BR
SPECTRAL RESPONSE
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Instrumentation
Character recognition
Laser detection
Fiber optic
RESPONSIVITY (A/W)
FEATURES
High speed
Low capacitance
Blue enhanced
Low dark current
很抱歉,暂时无法提供与“PDB-C102-I”相匹配的价格&库存,您可以联系我们找货
