PDB-C100
PDB-C100
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-3金属罐
    PHOTODIODE BLUE 0.59MM SQ TO-46
PDB-C100 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Isolated Type PDB-C100 DETECTORS INC. PACKAGE DIMENSIONS inch [mm] .145 [3.68] .040 [1.02] .042 [1.06] .068 [1.73] ±.03 [0.8] .73 [18.5] CL .100 [2.54] 45° CL 83° VIEWING ANGLE ANODE CATHODE CASE GROUND HEADER .155 [3.94] .184 [4.66] .210 [5.33] WIDOW CAP PHOTODIODE CHIP (WELDED) .047 [1.19] SQ CERAMIC STANDOFF Ø.034 [Ø0.86] ACTIVE AREA TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 0.59 mm2 FEATURES High speed Low capacitance Isolated chip Low dark current 0.5 C mA 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC SYMBOL CHARACTERISTIC TEST CONDITIONS ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 15 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance MIN TYP 9 11 1.0 MAX UNITS mA 2.0 nA GW H = 0, VR = 10 mV -8 % / oC H = 0, V R = 15 V** 5 Spectral Application Range Spot Scan lp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 mA Noise Equivalent Power VR = 15 V @ Peak Response Time RL = 50 W VR = 15 V tr unless otherwise noted) 5 l range NEP 1200 Light Current O 0.3 1000 IL +240 C % 1100 Soldering Temperature* +125 C 00 800 TS -40 O =1 900 Operating Temperature Range O QE 0.4 600 TO +150 0.5 700 -55 0.6 400 Storage Temperature V 500 100 190 TSTG Reverse Voltage SPECTRAL RESPONSE 0.7 300 VBR APPLICATIONS Fiber optic Industrial controls Laser detection Particle detection RESPONSIVITY (A/W) DESCRIPTION The PDB-C100 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive & fiberoptic applications.Packaged in a hermetic TO-46 metal can with a flat window and isolated ground lead. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS .50 400 850 100 125 7 pF 1150 nm nm V 40x10-15 W/ Hz 3 nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1MHz [FORM NO. 100-PDB-C100 REV N/C]
PDB-C100 价格&库存
很抱歉,暂时无法提供与“PDB-C100”相匹配的价格&库存,您可以联系我们找货
