PDB-C112
PDB-C112
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    模块
    PHOTODIODE BLUE 100MM SQ BNC
PDB-C112 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C112 DETECTORS INC. PACKAGE DIMENSIONS inch (mm) 0.175 [4.45] 0.073 [1.85] PHOTODIODE ACTIVE SURFACE TO TOP OF WINDOW PWB WINDOW Ø0.975 [Ø24.77] Ø0.4447 [Ø11.295] ACTIVE AREA (100 mm ) BLACK EPOXY HOUSING 4X WIRE BONDS 104° VIEWING ANGLE Ø0.625 [Ø15.88] SOLDER Ø0.695 [Ø17.65] PHOTODIODE CHIP 0.400 [10.16] 1.045 [26.54] CAP CATHODE AMP BNC CONNECTOR, ANODE BNC CONNECTOR PACKAGE ACTIVE AREA = .4447 (11.295) DIA = 100 mm2 C Operating Temperature Range -10 +60 TS Soldering Temperature* N/A N/A O 0.5 mA Imax Light Current 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC ID RSH TC RSH CJ Short Circuit Current H = 100 fc, 2850 K Dark Current H = 0, VR = 10V Shunt Resistance H = 0, VR = 10 mV RSH Temp. Coefficient Junction Capacitance 1.0 10 UNITS mA 30 nA MW H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10V** 300 pF Spectral Application Range Spot Scan lp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I= 10 µA NEP Noise Equivalent Power VR = 10 @ Peak Response Time RL = 1 KW VR = 50V 15 MAX 1.3 30 lrange tr % 1200 C TO 00 1100 C O =1 900 O QE 0.4 1000 +70 0.5 800 -20 0.6 700 Storage Temperature V 600 100 0.7 500 TS Reverse Voltage SPECTRAL RESPONSE 400 VBR · · · · 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Power meters Colorimeters Laser power meters 190 · · · · DESCRIPTION Large area, instrumentation grade, blue enhanced silicon photodiode. Designed for low capacitance high speed photoconductive applications. Packaged in a BNC connector package. RESPONSIVITY FEATURES Blue enhanced Photoconductive High speed Low dark current 350 1100 nm 950 30 nm 50 3x10-13 25 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-C112 REV A]
PDB-C112 价格&库存
很抱歉,暂时无法提供与“PDB-C112”相匹配的价格&库存,您可以联系我们找货
