PDB-C119
PDB-C119
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 7.95MM SQ TO-5
PDB-C119 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C119 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] CL 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° CL Ø0.358 [9.09] CL 68° VIEWING ANGLE 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] HEADER CATHODE Ø0.018 [0.46] PHOTODIODE 0.125 [3.175] SQ 0.113 [2.87] SQ ACTIVE AREA TO-5 HERMETIC LENS CAN PACKAGE ACTIVE AREA = 7.95 mm2 DESCRIPTION The PDB-C119 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-5 metal can with a glass window cap. +125 O +240 O IL Light Current 0.5 C C mA 0 .3 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH MAX UNITS mA 90 110 150 300 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V** 60 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr 1200 -40 % 1000 Operating Temperature Range 0 .4 00 1100 TO C =1 800 O QE 900 +150 0 .5 600 -55 0 .6 700 Storage Temperature Soldering Temperature* V 400 TSTG TS 100 500 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Bar code detector Encoder sensor Laser detection Instrumentation RESPONSIVITY (A/W) FEATURES Wide view angle High speed Large active area Low dark current 5 350 950 75 20 nA 150 pF 1100 nm nm 100 5x10-14 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.** f = 1 MHz [FORM NO. 100-PDB-C119 REV N/C]
PDB-C119 价格&库存
很抱歉,暂时无法提供与“PDB-C119”相匹配的价格&库存,您可以联系我们找货
