PDI-C115-F
PDI-C115-F
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE IR 5.07MM SQ TO-5
PDI-C115-F 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Near I.R. Photoconductive Type PDI-C115-F PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] CL 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° CL Ø0.358 [9.09] 73° VIEWING ANGLE CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] I.R. PASS FILTER HEADER PHOTODIODE 0.110 [2.79] SQUARE Ø0.100 [Ø2.54] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 5.07 mm2 -40 +80 O C +240 O C TS Soldering Temperature* IL Light Current 1.0 mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 Operating Temperature Range 1100 C TO 900 O 0% 10 1000 +100 = 800 -55 QE 0.4 700 Storage Temperature 0.5 600 TSTG 0.6 500 V 400 100 300 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) DESCRIPTION The PDI-C115-F is a silicon, PIN planar I.R. pass visible rejection diffused photodiode with NIR pass, visible Match to I.R. emitters light rejection optical filter. Ideal for high speed, low capacitance, photoconductive Hermetic package NIR applications. Packaged in a hermetic TO-5 metal can with a flat window cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS I.R. detector I.R. laser detector Photo-interrupters Industrial controls FEATURES High speed WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 10 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ V R = 50 V 40 5.0 nA 2 GΩ -8 % / oC 15 pF 700 1100 950 100 UNITS mA 59 1.0 .5 MAX nm 125 V -14 2.5x10 15 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz
PDI-C115-F 价格&库存
很抱歉,暂时无法提供与“PDI-C115-F”相匹配的价格&库存,您可以联系我们找货
