PDB-C114
PDB-C114
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 17.63MM SQ TO-5
PDB-C114 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C114 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] 0.075 [1.91] WIRE BONDS CL 0.500 [12.70] MIN 45° Ø0.358 [9.09] 63° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.235 [5.97] ACTIVE 0.123 [3.12] AREA 0.135 [3.43] TO-5 HERMETIC CAN PACKAGE 0.223 [5.66] ACTIVE AREA ACTIVE AREA = 17.63 mm2 APPLICATIONS DESCRIPTION The PDB-C114 is a silicon, PIN planar Instrumentation diffused, blue enhanced photodiode. Ideal Industrial controls for high speed photoconductive applications. Laser detection Packaged in a hermetic TO-5 metal can Optical power meters with a flat window. +125 O +240 O IL Light Current 0.5 C C mA 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH MAX UNITS mA 190 235 150 500 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V** 50 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr 1200 -40 0 .3 1000 Operating Temperature Range QE 0 .4 % 1100 TO C 00 800 O =1 900 +150 0 .5 600 -55 0 .6 700 Storage Temperature Soldering Temperature* V 400 TSTG TS 100 500 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 3 350 1100 950 100 8.0 nA nm nm 125 5.0x10-14 20 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDB-C114 REV B]
PDB-C114 价格&库存
很抱歉,暂时无法提供与“PDB-C114”相匹配的价格&库存,您可以联系我们找货
