PDB-C119-L
PDB-C119-L
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 7.95MM SQ TO-5
PDB-C119-L 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC.(OP913SL Industry Equivalent) Lens Type PDB-C119-L PACKAGE DIMENSIONS INCH [mm] LENS CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] CL 0.030 [0.76] WIRE 20° BONDS VIEWING 45° ANGLE Ø0.358 [9.09] 0.075 [1.91] 0.500 [12.70] MIN CL CL 0.200 [5.08] 0.035 [0.89] HEADER PHOTODIODE 0.125 [3.175] SQ 0.113 [2.87] SQ ACTIVE AREA CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] 0.260 [6.60] 0.348 [8.84] TO-5 HERMETIC LENS CAN PACKAGE ACTIVE AREA = 7.95 mm2 DESCRIPTION The PDB-C119-L is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-5 metal can with a glass lens window cap. -40 +125 TS Soldering Temperature* +240 O IL Light Current C C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 Operating Temperature Range 0.3 1100 TO O 500 C 900 O 1000 +150 0.4 800 -55 % 00 =1 E Q 0.5 700 Storage Temperature 0.6 600 V 500 100 400 TSTG Reverse Voltage 0.7 300 V BR SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Bar code detector Encoder sensor Laser detection Instrumentation RESPONSIVITY (A/W) FEATURES Narrow angle High speed Large active area Low dark current 90 MAX mA 110 5 UNITS 20 nA 300 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 10 V** 60 Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V 150 350 75 150 pF 1100 nm 950 nm 100 V -14 5x10 50 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.** f = 1 MHz [FORM NO. 100-PDB-C119-L REV B]
PDB-C119-L 价格&库存
很抱歉,暂时无法提供与“PDB-C119-L”相匹配的价格&库存,您可以联系我们找货
