PDB-C111
PDB-C111
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-8密封
    PHOTODIODE BLUE 100.2 TO-8.795
PDB-C111 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C111 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) Ø0.795 Ø[20.19] Ø0.500 BC Ø[12.70] BC Ø0.720 Ø[18.29] 0.225 [5.72] 0.159 [4.04] WINDOW CAP Ø0.608 Ø[15.44] ANODE 0.375 [9.53] Ø0.030 [0.76] TYP WIRE BONDS VIEWING ANGLE 54° Ø0.4447 ACTIVE AREA HEADER 0.030[0.76] PHOTODIODE CHIP UNUSED PIN 0.189[4.80] TO-8 .795 INCH (20.19) DIA HERMETIC PACKAGE CATHODE CASE GROUND 2 ACTIVE AREA = 100.20 mm 0.5 C mA 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K 1.0 MAX 1.3 10 UNITS mA 30 nA 30 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V** 300 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr 1 20 0 Light Current O 0 .3 1 10 0 IL +240 C % 9 00 Soldering Temperature* +125 C 00 1 00 0 TS -40 O =1 8 00 Operating Temperature Range O QE 0 .4 7 00 TO +150 0 .5 6 00 -55 0 .6 5 00 Storage Temperature V 4 00 100 3 00 TSTG Reverse Voltage SPECTRAL RESPONSE 0 .7 1 90 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Instrumentation Power meters Colorimeters Laser power meters DESCRIPTION The PDB-C111 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic jumbo TO-8 metal can with a flat window. RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 15 350 1100 950 30 nm nm 50 3x10-13 25 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-C111 REV B]
PDB-C111 价格&库存
很抱歉,暂时无法提供与“PDB-C111”相匹配的价格&库存,您可以联系我们找货
