PDB-C108
PDB-C108
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE BLUE 31MM SQ TO-8
PDB-C108 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Type PDB-C108 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.215 [5.46] Ø0.483 [12.27] 0.065 [1.65] Ø0.449 [11.39] 1.500 [38.10] WIRE BONDS CL 69° VIEWING ANGLE Ø0.550 [13.97] ANODE Ø0.018 [0.46] 0.295 [7.49] CL CATHODE Ø0.018 [0.46] HEADER PHOTODIODE WINDOW CAP (WELDED) 0.265 [6.74] SQUARE 0.2472 [6.289] ACTIVE AREA TO-8 HERMETIC PACKAGE ACTIVE AREA = 31.00 mm2 DESCRIPTION The PDB-C108 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-8 metal can with a flat window. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K MAX UNITS mA 400 460 65 120 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V** 75 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr 1200 IL +240 C % 1100 Soldering Temperature* +125 C 00 900 TS -40 O =1 1000 Operating Temperature Range O QE 0.4 700 TO +150 0.5 800 -55 0.6 500 Storage Temperature V 600 100 400 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Industrial controls Photoelectric switches Flame sensors RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 5 350 1100 950 100 15 nA nm nm 125 8x10-13 20 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-C108 REV B]
PDB-C108 价格&库存
很抱歉,暂时无法提供与“PDB-C108”相匹配的价格&库存,您可以联系我们找货
