PDI-C109-F
PDI-C109-F
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE IR 42.86MM SQ TO-8
PDI-C109-F 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Near I.R. Photoconductive Type PDI-C109-F PACKAGE DIMENSIONS INCH [mm] Ø0.483 [12.27] Ø0.449 [11.39] 0.215 [5.46] 0.065 [1.65] WIRE BONDS 1.50 [38.1] CL 79° VIEWING ANGLE Ø0.550 [13.97] PHOTODIODE I.R. PASS FILTER 0.295 [7.49] ANODE Ø0.018 [0.46] CL CATHODE Ø0.018 [0.46] HEADER WINDOW CAP (WELDED) 0.340 [8.64] 0.230 [5.84] 0.209 [5.31] ACTIVE AREA TO-8 HERMETIC CAN PACKAGE 0.319 [8.10] ACTIVE AREA ACTIVE AREA = 42.86 mm2 +80 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 -40 1100 Operating Temperature Range 0.4 900 TO C 1000 O 800 +100 700 -55 % 00 =1 E Q 0.5 600 Storage Temperature 0.6 500 TSTG 500 V 400 100 300 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) DESCRIPTION The PDI-C109-F is a silicon, PIN planar I.R. pass visible rejection diffused photodiode with NIR pass, visible Match to I.R. emitters light rejection optical filter. Ideal for high speed, low capacitance, photoconductive Hermetic package NIR applications. Packaged in a hermetic TO-8 metal can with a flat window cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS I.R. detector I.R. laser detector Photo-interrupters Industrial controls FEATURES High speed 405 MAX mA 450 5 UNITS 15 nA 100 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 10 V** 120 pF Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V 30 700 30 1100 nm 950 nm 50 V -13 5x10 25 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDI-C109-F REV A]
PDI-C109-F 价格&库存
很抱歉,暂时无法提供与“PDI-C109-F”相匹配的价格&库存,您可以联系我们找货
