PDB-C120-I
PDB-C120-I
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO18-3
    PHOTODIODE BLUE 0.073MM SQ TO-18
PDB-C120-I 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Isolated Type PDB-C120-I DETECTORS INC. PACKAGE DIMENSIONS inch [mm] Ø0.184 [4.67] 0.198 [5.03] WINDOW CAP (WELDED) Ø0.155 [3.94] 0.125 [3.18] 0.500 [12.70] MIN Ø 0.100 B.C. PHOTODIODE CHIP C L Ø0.210 [5.33] 45° Ø0.019 [0.48] Ø0.016 [0.41] 3 PLACES 0.040 [1.02] CASE GROUND C L HEADER 0.042 [1.06] CATHODE ANODE 0.027 [0.69] SQ Ø0.012 [Ø0.30] ACTIVE AREA TO-18 HERMETIC CAN PACKAGE ACTIVE AREA = 0.073 mm2 DESCRIPTION The PDB-C120-I is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-18 metal can with a flat window and isolated ground lead. Soldering Temperature* IL Light Current +125 +240 O 0.5 C C C mA 0.2 0.1 0 WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC SYMBOL CHARACTERISTIC TEST CONDITIONS unless otherwise noted) MIN TYP 1.2 1.5 400 500 MW H = 0, VR = 10 mV -8 % / oC H = 0, V R = 10 V** 1 pF ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance l range Spectral Application Range Spot Scan lp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 mA Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KW VR = 50 V tr % 0.3 *1/16 inch from case for 3 secs max NEP 00 1200 TS -55 O =1 1000 Operating Temperature Range O QE 0.4 1100 TO +150 0.5 800 -65 0.6 900 Storage Temperature V 600 200 700 Reverse Voltage UNITS 400 MAX 500 TSTG MIN 0.7 190 VBR SPECTRAL RESPONSE (TA=25OC unless otherwise noted) 300 ABSOLUTE MAXIMUM RATING SYMBOL PARAMETER APPLICATIONS Fiber optic Laser detection Light demodulation Matched to I.R. LEDs RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 0.5 350 150 UNITS mA 2.0 1100 950 100 MAX nA nm nm V 9.0x10-15 W/ Hz 1.0 nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1MHz [FORM NO. 100-PDB-C120-I REV N/C]
PDB-C120-I 价格&库存
很抱歉,暂时无法提供与“PDB-C120-I”相匹配的价格&库存,您可以联系我们找货
