PDB-C120
PDB-C120
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE BLUE 0.073MM SQ TO-46
PDB-C120 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC. (MRD 510) Industry Equivalent Type PDB-C120 PACKAGE DIMENSIONS INCH [mm] CL 0.145 [3.68] 0.040 [1.02] 0.50 [12.7] MIN CL 0.145 [3.68] Ø0.019 [0.48] Ø0.016 [0.41] WIRE BOND Ø0.195 [4.95] Ø0.178 [4.52] CL 0.100 [2.54] ANODE CL Ø0.212 [5.38] Ø0.209 [5.31] 0.027 [0.69] SQUARE Ø0.012 [Ø0.30] ACTIVE AREA CATHODE & CASE PHOTODIODE CHIP WINDOW CAP (WELDED) HEADER 0.025 [0.64] 0.022 [0.56] TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 0.073 mm2 DESCRIPTION The PDB-C120 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-46 metal can with a flat window. Operating Temperature Range -55 +125 O TS Soldering Temperature* +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ 1.2 MAX UNITS mA 1.5 0.5 2.0 nA 500 MΩ H = 0, V R = 10 mV -8 % / oC Junction Capacitance H = 0, V R = 10 V** 1 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 m A RSH NEP tr 1200 TO C 1100 O 900 +150 1000 -65 800 Storage Temperature 0.4 700 TSTG % 00 =1 QE 0.5 600 V 500 200 400 Reverse Voltage 0.6 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Fiber optic Laser detection Light demodulation Matched to I.R. LEDs RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V 400 350 1100 950 100 nm 150 V -15 9.0x10 1.0 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDB-C120 REV B]
PDB-C120 价格&库存
很抱歉,暂时无法提供与“PDB-C120”相匹配的价格&库存,您可以联系我们找货
