PHOTONIC
DETECTORS INC.
Silicon Photodiode, Near I.R. Photoconductive
Type PDI-C119-F
PACKAGE DIMENSIONS INCH [mm]
WINDOW CAP
(WELDED)
0.030 [0.76]
Ø0.325 [8.25]
Ø0.250 [6.35]
CL
0.168 [4.26]
0.075 [1.91]
WIRE
BONDS
0.500
[12.70]
MIN
45°
Ø0.358
[9.09]
78°
VIEWING
ANGLE
CL
0.200 [5.08]
0.035
[0.89]
CL
ANODE
Ø0.018 [0.46]
CATHODE
Ø0.018 [0.46]
I.R. PASS FILTER
HEADER
PHOTODIODE
CL
0.125 [3.18]
0.113 [2.87]
ACTIVE AREA
TO-5 HERMETIC CAN PACKAGE
0.113 [2.87]
ACTIVE AREA
ACTIVE AREA = 7.95 mm2
0.5
C
mA
0.1
WAVELENGTH (nm)
*1/16 inch from case for 3 secs max
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
λrange
λp
V BR
NEP
tr
1200
Light Current
O
0.2
1100
IL
+240
C
0.3
900
Soldering Temperature*
-40
0.4
1000
TS
+80
O
C
800
Operating Temperature Range
O
0%
700
TO
+100
=1
QE
0.5
600
-55
0.6
500
Storage Temperature
V
400
TSTG
100
300
Reverse Voltage
0.7
190
V BR
SPECTRAL RESPONSE
RESPONSIVITY (A/W)
DESCRIPTION
The PDI-C119-F is a silicon, PIN planar
I.R. pass visible rejection diffused photodiode with NIR pass, visible
Match to I.R. emitters light rejection optical filter. Ideal for high
speed, low capacitance, photoconductive
Hermetic package
NIR applications. Packaged in a hermetic
TO-5 metal can with a flat window cap.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
I.R. detector
I.R. laser detector
Photo-interrupters
Industrial controls
FEATURES
High speed
45
MAX
UNITS
mA
50
5
nA
300
MΩ
H = 0, V R = 10 mV
-8
% / oC
H = 0, V R = 10 V**
60
Spectral Application Range Spot Scan
Spectral Response - Peak
Spot Scan
Breakdown Voltage
I = 10 m A
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 10 V
150
700
75
150
pF
1100
nm
950
nm
100
V
-14
5x10
50
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. ** f = 1 MHz
[FORM NO. 100-PDI-C119-F REV A]
很抱歉,暂时无法提供与“PDI-C119-F”相匹配的价格&库存,您可以联系我们找货
