PHOTONIC
Silicon Photodiode, Blue Enhanced Photoconductive
Type PDB-C105
DETECTORS INC.
PACKAGE DIMENSIONS INCH [mm]
WINDOW CAP
(WELDED)
0.030 [0.76]
Ø0.325 [8.25]
Ø0.250 [6.35]
CL
0.168 [4.26]
0.075 [1.91]
WIRE
BONDS
0.500
[12.70]
MIN
45°
Ø0.358
[9.09]
78°
VIEWING
ANGLE
CL
CL
0.200 [5.08]
0.035
[0.89]
CL
ANODE
Ø0.018 [0.46]
CATHODE
Ø0.018 [0.46]
HEADER
PHOTODIODE
0.095 [2.41] SQ
0.086 [2.18] SQ ACTIVE
AREA
TO-5 HERMETIC CAN PACKAGE
ACTIVE AREA = 4.48 mm2
DESCRIPTION
The PDB-C105 is a silicon, PIN planar
diffused, blue enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a hermetic TO-5 metal can
with a flat window.
+125
O
+240
O
IL
Light Current
0.5
C
C
mA
0 .3
0 .2
0 .1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 10 V
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
MAX
UNITS
mA
40
56
.5
2.0
GΩ
H = 0, VR = 10 mV
-8
% / oC
H = 0, VR = 10 V**
11
pF
λrange
Spectral Application Range
Spot Scan
λp
Spectral Response - Peak
Spot Scan
V BR
Breakdown Voltage
I = 10 mA
N EP
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 50 V
tr
1200
-40
1000
Operating Temperature Range
0 .4
00
1100
TO
C
=1
800
O
QE
900
+150
0 .5
600
-55
0 .6
700
Storage Temperature
Soldering Temperature*
V
400
TSTG
TS
100
500
Reverse Voltage
190
V BR
SPECTRAL RESPONSE
0 .7
300
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Instrumentation
Laser detection
Medical sensor
Industrial control
RESPONSIVITY (A/W)
FEATURES
High speed
Low capacitance
Blue enhanced
Low dark current
1.0
350
1100
950
100
5.0
nA
nm
nm
125
2.0x10-14
12
V
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.** f = 1 MHz
[FORM NO. 100-PDB-C105 REV B]
很抱歉,暂时无法提供与“PDB-C105”相匹配的价格&库存,您可以联系我们找货
