PDB-C104-I
PDB-C104-I
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO18-3
    PHOTODIODE BLUE 2.98MM SQ TO-18
PDB-C104-I 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Isolated Type PDB-C104-I DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] Ø0.184 [4.67] Ø0.155 [3.94] WINDOW CAP (WELDED) 0.198 [5.03] WIRE BONDS 0.500 [12.70] MIN 0.125 [3.18] Ø0.100 B.C. PHOTODIODE CHIP CL Ø0.210 [5.33] 45° 0.040 [1.02] C L 0.042 [1.06] Ø0.019 [0.48] 3 PLACES Ø0.016 [0.41] CASE GROUND CATHODE ANODE HEADER 0.125 [3.18] 0.066 [1.68] 0.046 [1.17] ACTIVE AREA TO-18 HERMETIC CAN PACKAGE 0.104 [2.64] ACTIVE AREA ACTIVE AREA = 2.98 mm2 DESCRIPTION The PDB-C104-I is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-18 metal can with a flat window and isolated ground lead. Operating Temperature Range -40 +125 O C +240 O C TS Soldering Temperature* IL Light Current 0.5 mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V RSH Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 10 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power V R = 10 V @ Peak Response Time RL = 1 KΩ V R = 50 V 40 1.0 nA 1.0 GΩ -8 % / oC 10 pF 350 1100 950 70 UNITS mA 45 .15 .5 MAX nm 100 V -14 1.5x10 10 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz 1200 C TO 1100 O 900 +150 1000 -55 0.4 800 Storage Temperature % 00 =1 QE 0.5 700 TSTG 0.6 600 V 500 100 400 Reverse Voltage 0.7 300 V BR SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Character recognition Laser detection Fiber optic RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current
PDB-C104-I 价格&库存
很抱歉,暂时无法提供与“PDB-C104-I”相匹配的价格&库存,您可以联系我们找货
