PDB-C133
PDB-C133
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Through Hole
    PHOTODIODE BLUE 0.65MM SQ T1 CLR
PDB-C133 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC. Type PDB-C133 , with daylight filter Type PDB-C133F PACKAGE DIMENSIONS INCH [mm] 0.150 [3.80] Ø0.118 [3.00] 0.020 [0.51] SQ 2 PLACES ACTIVE AREA SURFACE 1.04 [26.5] C L 0.100 [2.54] C L 30° VIEWING ANGLE 0.035 [0.90] CATHODE 0.98 [25.0] ANODE CLEAR PLASTIC (PDB-C133) BLACK PLASTIC (PDB-C133F) 0.100 [2.54] CHIP POSITION 0.209 [5.30] 0.038 [0.97] SQ 0.032 [0.81] SQ ACTIVE AREA T 1 PLASTIC PACKAGE ACTIVE AREA = 0.65 mm2 DESCRIPTION: The PDB-C133 detector is a 0.65 mm2 planar pin photodiode packaged in a T 1 , water clear plastic housing. Designed for high speed, low capacitance, photoconductive applications. The PDB-C133F includes a daylight filter. -40 +80 O TS Soldering Temperature* +260 O IL Light Current C C mA 0 .3 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance λrange MAX UNITS mA 12 15 .5 5 GΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V* 2 Spectral Application Range (without daylight filter)** λp Spectral Response - Peak VBR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr * * * * * * * * * ** 1 20 0 Operating Temperature Range 0 .4 1 10 0 TO C 9 00 O 1 00 0 +100 * * * * * * 8 00 -40 % 00 =1 QE 0 .5 7 00 Storage Temperature 0 .6 6 00 TSTG 0.5 V 5 00 100 4 00 Reverse Voltage 3 00 VBR SPECTRAL RESPONSE 0 .7 1 90 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Smoke detectors Light pen detectors TV & VCR remotes RESPONSIVITY (A/W) FEATURES Photoconductive High speed Low cost 2 400 5 1100 950 50 10 nA pF nm nm 100 1.5x10-13 5 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. *f = 1 MHz, ** daylight filter= 700 - 1100 nm [FORM NO. 100-PDB-C133 REV A]
PDB-C133 价格&库存
很抱歉,暂时无法提供与“PDB-C133”相匹配的价格&库存,您可以联系我们找货
