PHOTONIC
Silicon Photodiode, Blue Enhanced
DETECTORS INC.
Photoconductive
Type PDB-C120L
PACKAGE DIMENSIONS
INCH [mm]
C
L
45°
0.040
[1.02]
0.145 [3.68]
0.50 [12.7] MIN
CL
0.189 [4.80]
0.029 [0.74]
Ø0.019 [0.48]
Ø0.016 [0.41]
WIRE
BOND
Ø0.195 [4.95]
Ø0.178 [4.52]
CL
0.100 [2.54]
ANODE
CL
CATHODE
& CASE
PHOTODIODE CHIP
Ø0.212 [5.38]
Ø0.209 [5.31]
LENS CAP
(WELDED)
0.027 [0.69]
SQUARE
Ø0.012 [Ø0.30]
ACTIVE AREA
0.025 [0.64]
0.022 [0.56]
HEADER
TO-46 HERMETIC CAN PACKAGE
ACTIVE AREA = 0.073 mm2
DESCRIPTION
The PDB-C120L is a silicon, PIN planar
diffused, blue enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a hermetic TO-46 metal can
with a glass lens cap.
Operating Temperature Range
-55
+125
O
TS
Soldering Temperature*
+240
O
IL
Light Current
500
C
C
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
1.2
MAX
UNITS
mA
1.5
0.5
2.0
nA
500
MΩ
H = 0, V R = 10 mV
-8
% / oC
Junction Capacitance
H = 0, V R = 10 V**
1
pF
λrange
Spectral Application Range
Spot Scan
λp
Spectral Response - Peak
Spot Scan
VBR
Breakdown Voltage
I = 10 m A
RSH
NEP
tr
1200
TO
C
1100
O
900
+150
1000
-65
0.4
800
Storage Temperature
00
=1
QE
0.5
700
TSTG
0.6
600
V
500
200
400
Reverse Voltage
300
VBR
SPECTRAL RESPONSE
0.7
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Fiber optic
Laser detection
Light demodulation
Matched to I.R. LEDs
RESPONSIVITY (A/W)
FEATURES
High speed
Low capacitance
Blue enhanced
Low dark current
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 50 V
400
350
1100
950
100
nm
150
V
-15
9.0x10
1.0
nm
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. ** f = 1 MHz
[FORM NO. 100-PDB-C120L REV A]
很抱歉,暂时无法提供与“PDB-C120-L”相匹配的价格&库存,您可以联系我们找货
