PDB-C157F
PDB-C157F
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    侧视图
    PHOTODIODE BLUE W/DF 8.09MM BLK
PDB-C157F 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC. Type PDB-C157 , with daylight filter Type PDB-C157F PACKAGE DIMENSIONS INCH [mm] CLEAR PLASTIC [PDB-C157] BLACK PLASTIC [PDB-C157F] 0.256 [6.50] 0.095 [2.40] C L 0.65 [16.5] CATHODE Ø0.200 [5.08] 0.100 [2.54] C L 120° VIEWING ANGLE C L 0.100 [2.54] C L ACTIVE AREA SURFACE ANODE 0.020 [0.50] SQ 2 PLACES 0.030 [0.76] 0.146 [3.71] 0.75 [19.0] 0.125 [3.18] SQUARE ACTIVE AREA 0.112 [2.84] SQUARE PLASTIC SIDELOOKER PACKAGE ACTIVE AREA = 8.09 mm2 DESCRIPTION: The PDB-C157 detector is a 8.09 mm2 planar pin photodiode packaged in a water clear plastic sidelooker housing. Designed for high speed, low capacitance, photoconductive applications. The PDB-C157F includes a daylight filter. -40 +80 O TS Soldering Temperature* +260 O IL Light Current C C mA 0 .3 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance λrange MAX UNITS mA 85 120 100 150 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V* 30 Spectral Application Range (without daylight filter)** λp Spectral Response - Peak VBR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr * * * * * * * * * ** 1 20 0 Operating Temperature Range 0 .4 1 10 0 TO C 9 00 O 1 00 0 +100 * * * * * * 8 00 -40 % 00 =1 QE 0 .5 7 00 Storage Temperature 0 .6 6 00 TSTG 0.5 V 5 00 50 4 00 Reverse Voltage 3 00 VBR SPECTRAL RESPONSE 0 .7 1 90 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Smoke detectors Bar code TV & VCR remotes Dimmers RESPONSIVITY (A/W) FEATURES Large active area Photoconductive Low cost High speed 2 400 50 1100 950 30 30 nA pF nm nm 75 4.4x10-14 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. *f = 1 MHz, ** daylight filter= 700 - 1100 nm [FORM NO. 100-PDB-C157 REV A]
PDB-C157F 价格&库存
很抱歉,暂时无法提供与“PDB-C157F”相匹配的价格&库存,您可以联系我们找货
