PDB-V101-I
PDB-V101-I
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO18-3
    PHOTODIODE BLUE 0.31MM SQ TO-18
PDB-V101-I 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Isolated Type PDB-V101-I DETECTORS INC. PACKAGE DIMENSIONS inch [mm] Ø0.184 [4.67] WINDOW CAP (WELDED) Ø0.155 [3.94] 0.198 [5.03] 0.125 [3.18] WIRE BONDS 0.500 [12.70] MIN Ø0.100 B.C. PHOTODIODE CHIP CL Ø0.210 [5.33] 45° 0.040 [1.02] C L CASE GROUND CATHODE HEADER 0.042 [1.06] ANODE Ø0.019 [0.48] 3 PLACES Ø0.016 [0.41] 0.053 [1.35] SQUARE Ø0.0247 [Ø0.627] ACTIVE AREA TO-18 HERMETIC CAN PACKAGE ACTIVE AREA = 0.31 mm2 DESCRIPTION The PDB-V101-I is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-18 metal can with a flat window and isolated ground lead. Operating Temperature Range -40 +125 O C +240 O C TS Soldering Temperature* IL Light Current .5 mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V RSH Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** l range Spectral Application Range Spot Scan lp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A NEP tr 4 45 pA 1.6 GW W -8 % / oC 115 pF 350 1100 950 30 UNITS mA 4.5 20 1 MAX nm nm 50 V -15 Noise Equivalent Power V R = 10 mV @ Peak 2.5x10 Response Time RL = 1 KW V R = 0 V 450 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz 1200 C TO 0% 10 1100 O = 900 +150 QE 1000 -55 0.4 800 Storage Temperature 0.5 700 TSTG 0.6 600 V 500 75 400 Reverse Voltage 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Industrial controls Laser detection Particle detection RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response
PDB-V101-I 价格&库存
很抱歉,暂时无法提供与“PDB-V101-I”相匹配的价格&库存,您可以联系我们找货
