PDB-C159
PDB-C159
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    侧视图
    PHOTODIODE BLUE 10.07MM SQ CLEAR
PDB-C159 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive with daylight filter Type PDB-C159F DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.591 [15.00] 0.118 [3.00] 0.299 [7.60] CATHODE CL 120° VIEWING ANGLE 0.276 [7.00] 0.200 [5.08] ANODE CL ACTIVE AREA SURFACE 0.020 [0.51] SQ 2 PLACES 0.039 [1.00] 0.091 [2.31] 0.091 [2.31] 0.197 [5.00] 0.135 [3.42] SQ C L 0.125 [3.17] SQ ACTIVE AREA PLASTIC SIDELOOKER PACKAGE ACTIVE AREA = 10.07 mm2 DESCRIPTION: The PDB-C159F detector is a 9.00 mm2 planar pin photodiode packaged in a black plastic sidelooker housing. Designed for high speed, low capacitance, photoconductive applications. The PDBC159F includes a daylight filter. Light Current O 500 C mA 0 .3 0 .2 0 .1 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance λrange MAX UNITS mA 59 68 75 100 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V* 15 Spectral Application Range (with daylight filter) λp Spectral Response - Peak VBR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr 0 1200 IL +240 C 1100 Soldering Temperature* -25 C 900 TS +85 O 1000 Operating Temperature Range O 0 .4 800 TO +100 % 00 =1 QE 0 .5 700 -30 0 .6 600 Storage Temperature V 500 50 400 TSTG Reverse Voltage 300 VBR SPECTRAL RESPONSE 0 .7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS I.R. links I.R. sensors I.R. remotes RESPONSIVITY (A/W) FEATURES Large active area High speed Low cost 5 700 20 1100 950 25 30 nA pF nm nm 30 7x10-13 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. *f = 1 MHz, [FORM NO. 100-PDB-C159 REV A]
PDB-C159 价格&库存
很抱歉,暂时无法提供与“PDB-C159”相匹配的价格&库存,您可以联系我们找货
