PDB-C136
PDB-C136
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Through Hole
    PHOTODIODE BLUE 1.55MM SQ T1 3/4
PDB-C136 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC. Type PDB-C136 , with daylight filter Type PDB-C136F PACKAGE DIMENSIONS INCH [mm] 0.213 [5.41] CLEAR PLASTIC (PDB-C138) BLACK PLASTIC (PDB-C138F) 0.047 [1.20] CHIP ACTIVE SURFACE Ø0.228 [5.80] Ø0.197 [5.00] 0.984 [25.00] MIN CATHODE C L 0.100 [2.54] C L 94° VIEWING ANGLE 0.020 [0.50] SQ 2 PLACES 0.060 [1.52] SQUARE ANODE 0.039 [1.00] 0.059 [1.50] MAX 1.043 [26.50] 0.049 [1.24] SQUARE ACTIVE AREA T 1 3/4 FLAT TOP PACKAGE ACTIVE AREA = 1.55 mm2 DESCRIPTION: The PDB-C136 detector is a 1.55 mm2 planar PIN photodiode packaged in a T 1 3/4, flat top, water clear plastic housing. Designed for high speed, low capacitance, photoconductive applications. The PDB-C136F includes a daylight filter. -40 +80 O TS Soldering Temperature* +260 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange 20 MAX UNITS mA 27 2 30 nA 2 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 10 V* 6 Spectral Application Range (without daylight filter)** λp Spectral Response - Peak VBR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr 1200 Operating Temperature Range 0.4 1100 TO C 900 O 1000 +100 800 -40 * * * * * * * * * * * * * * * ** 0% =10 QE 0.5 700 Storage Temperature 0.6 600 TSTG 500 V 500 100 400 Reverse Voltage 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Smoke detectors Light pen detectors Fiber optics Bar code detectors RESPONSIVITY (A/W) FEATURES Large active area Photoconductive Low cost High speed .5 400 950 50 pF 1100 nm nm 100 V 1.8x10 -13 10 10 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. * f = 1 MHz, ** daylight filter = 700 - 1100 nm [FORM NO. 100-PDB-C136 REV C]
PDB-C136 价格&库存
很抱歉,暂时无法提供与“PDB-C136”相匹配的价格&库存,您可以联系我们找货
