PDB-C166
PDB-C166
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    金属化陶瓷
    PHOTODIODE BLUE 4.41MM SQ CERMC
PDB-C166 数据手册
PHOTONIC Pulsed Oximeter, Silicon Photodiode, DETECTORS INC. Photoconductive Type PDB-C166 PACKAGE DIMENSIONS INCH (mm) METALIZED CERAMIC 2 SIDES PHOTODIODE CHIP .268 [6.81] C ANODE SOLDER PAD .289 [7.34] CATHODE SOLDER PAD A TOP VIEW CLEAR ENCAPSULATE BOTTOM VIEW 0.065 [1.65] MAX FRONT VIEW .025 [0.64] 0.115 [2.92] ACTIVE AREA 0.060 [1.51] ACTIVE AREA BACK SIDE CONTACT METALIZED CERAMIC PACKAGE 0.069 [1.74] 0.149 [3.78] ACTIVE AREA = 4.41 mm2 APPLICATIONS Pulsed oximetry Glucometers Pulse meters DESCRIPTION The PDB-C166 is a silicon, PIN planar diffused, photodiode. Ideal for many OEM pulsed oximeter probe assemblies . Packaged in a metalized ceramic substrate with back side anode and cathode contacts. -40 +80 O TS Soldering Temperature* +240 O IL Light Current C C mA 0 .3 0 .2 0 .1 0 WAVELENGTH (nm) *Temperature controlled soldering irons required with low temperature solder. Two second max dwell time. ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K UNITS mA 75 50 100 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V** 100 pF Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr MAX 60 λrange 1 350 10 1100 950 50 1200 Operating Temperature Range 0 .4 % 1000 TO C 00 1100 O =1 800 +100 QE 900 -45 0 .5 600 Storage Temperature 0 .6 700 TSTG 50.0 V 400 100 500 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed Specially matched to 660 nm and near IR emitters nA nm nm 75 2.0x10-14 15 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDB-C166 REV N/C]
PDB-C166 价格&库存
很抱歉,暂时无法提供与“PDB-C166”相匹配的价格&库存,您可以联系我们找货
